| RoadGlue |
Jul 26 2006, 08:29 PM
Sonoma County Gear Head ![]() ![]() ![]() ![]() Group: Admin Posts: 2,084 Joined: 8-January 03 From: Santa Rosa, CA Member No.: 108 Region Association: Northern California
The other night I was driving the '74 2.0 home and I noticed that the oil pressure idiot light was on, but very dimly. I pulled over right away, checked oil level, turned the car to "ON" (not start) and noticed that the oil light was on, but was bright like you'd expect it to be.
I debated having the car towed, but I've had what I thought was a similar problem with a bad pressure switch on another 914 and decided to drive it home. The car drove normally and the engine sounded perfect, though the oil light was still dimly staring back at me. Finally had a chance to swap out the sender tonight and it's acting the same way. Turn ignition switch to "ON" and it's bright. Start the car and it's on, but dim. It's a very solid dim. No flickering or changes in luminosity depending on engine RPM. There's no engine oil spewing out when the car's on either. (IMG:style_emoticons/default/smile.gif) I think there's a problem elsewhere. Obviously I need to make sure I have good oil pressure before driving it, and I'm going to borrow a screw in pressure gauge from my machinist friend before doing so. With that said, what are the odds that I have low oil pressure? 914s that I've had before with low oil pressure had idiot lights that flickered, usually brightly. If it's an electrical problem, where should I start digging? Thanks! |
| lapuwali |
Jul 26 2006, 08:50 PM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
Try dimming your dash lights. Perhaps the gauge light is bleeding into the oil pressure "window".
RoadGlue Oil pressure light on, but it's really dim Jul 26 2006, 08:29 PM
RoadGlue ![]() ![]() |
Lo-Fi Version | Time is now: 1st November 2026 - 01:59 AM |
