| Dr Evil |
Jul 28 2006, 03:53 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Well working on Chef's car yesterday made me feel more confident to learn what the hell is wrong with my car. Or the shorter list, what is right (IMG:style_emoticons/default/dry.gif)
So I cut a hole in the fire wall. I did this after much mental deliberation and figured since I am going ot be goofing with my DIS eventually this was an acceptable move. Also, the ass who installed the moter (me) must have been in a hurry and didnt mark the timing marks on the pully. This was quickly rectified today and it was found that my previous attemp to mark the fan housing en vivo was actually off the mark. Also, I have recently been goofing with the fuel mixture which was waaaayyyyyyy too rich before. (I'll make a list of questions at the end for all of you to ponder.) So, on to the timing. When I adjust the idle timing to 5 ATDC, hose attached, it idles fine now. BUT, when I disconnect the hose and rev it up to 6k RPM the timing does not advance smoothly and the marks are all over the place. Basically the timing is erratic and the car lacks power. I have even noticed the timing movement not advancing correctly, but going the wrong way instead. I am pretty sure this was withthe hose disconnected, but I have done this so manny times now that my head is spinning. Using an adjustable timing light I set it to 35 BTDC and noticed that with the idle set stock the timing was not retarded enough. When I adjusted it it ran like crap. This was done when the marks were all over the palce. I tred it with the advance on the light set to 0 and go the same thing. I think I am in need of another dizzy (which sucks because I am getting rid of the dizzy eventually). Basically, I am looking for faults and conditions to watch out for and what to check. I am fried so I may need to re test and clarify later. |
| Dr Evil |
Jul 28 2006, 08:16 PM
I have a set of wires I can raid (had to repair them already so I know how they are constructed) and the whole set up form the EDIS so I may not need anything. This is great news (IMG:style_emoticons/default/biggrin.gif)
I was just searching for my advance curves and here are my new questions: -Which curve should I use? I have a 2.4-2.7 except carrera curve, a 77 S curve, and a 78 SC curve (the wiredest one). My engine has SC cams. -Where can I find an advance curve with vacuum? I have only mechanical advance curves and nothing with what the vacuum does. |
Dr Evil Timing a /6 part 2 Jul 28 2006, 03:53 PM
Cap'n Krusty Take it out, take it apart, clean and lubricate it... Jul 28 2006, 03:58 PM
lapuwali And if a good clean and lube doesn't fix the d... Jul 28 2006, 04:01 PM
DNHunt Maybe it's just wants the crankfire early. It ... Jul 28 2006, 04:10 PM
Dr Evil More info from me would be good about now :D
What... Jul 28 2006, 05:14 PM
lapuwali There are charts around for the stock distributor ... Jul 28 2006, 07:15 PM
Dr Evil Ya, I have many charts that members have been so k... Jul 28 2006, 07:20 PM
lapuwali Plugs to interface? You mean plug wires? That... Jul 28 2006, 07:55 PM
Dr Evil James, I always appreciate the info that you post.... Jul 28 2006, 07:59 PM
lapuwali Someone on the Bird Board installed EDIS on their ... Jul 28 2006, 08:09 PM
Dr Evil More info for ya on what advance curves I have, al... Jul 28 2006, 08:42 PM
Dr Evil I am going to post a separate thread soliciting in... Jul 28 2006, 09:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 09:50 PM |
