> Proportioning valve advice, confused where to go from now
Hammy
post Jul 29 2006, 02:58 PM
mr. Wonderful
So this "quick" brake fix job has turned into another real headache. (IMG:style_emoticons/default/smile.gif) What's new?
Screwed up two of the rear brake hard lines when I was replacing the rubber lines. So we went down and bought some new metric hard lines at a FLAPS, they fit nicely, blah blah blah.
Now it appears that the threading for the right brake line IN the proportioning valve is stripped, and the brake line will screw into it but has a lot of play, is very loose and basically will for sure be leaking. (IMG:style_emoticons/default/huh.gif)
So now what do you think I should do? I've already spent so much on this brake fix job and I would *really* hate to spend 200 bucks on another P valve. The adjustable ones listed on PP say they're for track use only too. What about replacing with a T fitting? I've read of others doing that. Street car, stock brakes....
Thanks for any help...
Aaron Cox
post Jul 29 2006, 03:12 PM
Professional Tinkerer
im sure someone has a stock one somewhere for free...
i threw mine away...
do a T if you have bigger than stock front brakes....
Hammy   Proportioning valve advice   Jul 29 2006, 02:58 PM
Aaron Cox   im sure someone has a stock one somewhere for free...   Jul 29 2006, 03:12 PM
Brad Roberts   You probably didnt buy the adapters you need for a...   Jul 29 2006, 03:16 PM
Hammy   I didn't know there are adapters :blink:   Jul 29 2006, 03:20 PM
Aaron Cox
- Lo-Fi Version Time is now: 17th April 2026 - 05:06 AM
