| Hammy |
Jul 29 2006, 02:58 PM
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,828 Joined: 20-October 04 From: Columbia, CA./ Tuolumne Member No.: 2,978 Region Association: Northern California |
So this "quick" brake fix job has turned into another real headache. (IMG:style_emoticons/default/smile.gif) What's new?
Screwed up two of the rear brake hard lines when I was replacing the rubber lines. So we went down and bought some new metric hard lines at a FLAPS, they fit nicely, blah blah blah. Now it appears that the threading for the right brake line IN the proportioning valve is stripped, and the brake line will screw into it but has a lot of play, is very loose and basically will for sure be leaking. (IMG:style_emoticons/default/huh.gif) So now what do you think I should do? I've already spent so much on this brake fix job and I would *really* hate to spend 200 bucks on another P valve. The adjustable ones listed on PP say they're for track use only too. What about replacing with a T fitting? I've read of others doing that. Street car, stock brakes.... Thanks for any help... |
| Hammy |
Jul 29 2006, 03:20 PM
I didn't know there are adapters (IMG:style_emoticons/default/blink.gif)
| Aaron Cox |
Jul 29 2006, 03:21 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
i think brad is talking about a wilwood p-valve that requires metric adapters |
Hammy Proportioning valve advice Jul 29 2006, 02:58 PM
Aaron Cox im sure someone has a stock one somewhere for free... Jul 29 2006, 03:12 PM
Brad Roberts You probably didnt buy the adapters you need for a... Jul 29 2006, 03:16 PM
Aaron Cox ![]() ![]() |
Lo-Fi Version | Time is now: 17th April 2026 - 05:03 AM |
