Tranny Out!! (Clutch job), How much washer on the ball? |
Mark Henry |
Oct 14 2003, 10:37 PM
Got done early, so I yanked the transmission.
Found one leak, I took the clutch arm ball out by hand. (IMG:style_emoticons/default/blink.gif) It already has a .060 washer in it. I had to use ground down bolts to fit a new 4-spring disc in my clutch. So how much more washer should I use? |
Brad Roberts |
Oct 15 2003, 12:39 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
First off we use the 6 spring 911 disc..
Second.. if you have to grind the bolt heads down.. typically this means the flywheel needs replacing (you should know that..lol) The ball cannot handle being "hung" out of the case very far before it becomes a constant leak and rips the threads out. B |
Lo-Fi Version | Time is now: 7th June 2024 - 07:08 PM |
