96mm P&C what CR, Anyone checked the CR on a 96mm P/C |
fast914 |
Aug 1 2006, 06:02 PM
Newbie Group: Members Posts: 16 Joined: 4-May 06 From: USA Member No.: 5,975 |
I'm in the process of assembling the 2.0L. I just purchased a set of Pistons (and cylinders). The pistons are KB pistons flat top. I was told they yield 10:1CR. I blan on using a 0.060 spacer to lower the CR some.
Anyone ever used this combination? What CR did you calculate. I plan on CCing the head etc.. to come up with the actual CR, I just want to compare my results. I will be using the WebCam 86 grind. Would there be a need to shave the pistons for clearance? Can the push rods be used, or custom ones are needed? This is my first attemp to assemble a T4 engine.. Any hints will be appreciated.... TIA |
blitZ |
Aug 1 2006, 06:08 PM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
You can't calculate the CR until to CC the heads. I'm about to install the same flat top KB pistons with Mahle cylinders I got from Jake. My CR will be 9.2 with a CC of 59.2.
Here is one of several online compression gonkulators. CR Calculator |
Lo-Fi Version | Time is now: 11th June 2024 - 04:04 AM |
