> Wobblin' Gas Pedal, base rubber mounting getting old
DanT
post Aug 6 2006, 04:39 PM
Going back to the Dark Side!
At the last AX I went to I noticed the gas pedal was starting to move from side to side
in a strange unusual manner....still works fine but not confidence inspriring. (IMG:style_emoticons/default/confused24.gif)
Took a look at the base where it mounts to the floor...
Right side of mounting rubber seems to be pulling away from mounting screw....
Rubber is probably getting old...needs to be repaired or replaced.
So has anyone done any repairs to this area before....and if so what did you do and what did you use to perform the repair.
If not what are some good sources for a replacement.....or are they even available any more? (IMG:style_emoticons/default/blink.gif)
Thanks
Randal
post Aug 7 2006, 01:03 PM
QUOTE(Dan (Almaden Valley) @ Aug 6 2006, 03:39 PM) *
Thanks
This sounds just like a case of exessive force to me. (IMG:style_emoticons/default/biggrin.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 07:41 AM
