> GROUP BUY Programmable electronic fuel injection (, Is anyone interested in a SDS Group buy?
Mark Henry
post Feb 27 2003, 02:21 PM
that's what I do!
Programmable electronic fuel injection (PEFI)
Is anyone interested in a SDS PEFI GROUP BUY?
Base system list is $785 or $1165 for the full meal deal (crank trigger ignition) for the 4-cylinder version.(full list price, not counting discount)
Discount is 10% off for 2 systems and up to 25% off for 10 systems.
So that could = the base 4 cylinder system for approximately $600* or about the price of a new MPS.
*(Based on the basic system, no options with 10 people in the buy for a 25% discount, no shipping.)
This is for the brain only, many options, you must check out their site and decide what you want/need. Will work on the stock engine and intake system to get you going. Then you can go hipo crazy (cam, TB’s, stroker, etc.) if you want. (I think with a few options $800. to $1000.+ is maybe a more realistic cost per system.)
http://www.sdsefi.com/
The points I like about it are: you don’t need a laptop (which is good for me as I’m totally ‘puter stupid), the controller stays in the car, they will build it with a real CHT sender, they custom tailor the harness, the base system isn’t too expensive, info BBS, they have aircooled experience and the guy uses it on his own plane. A couple of bugs and a couple of 911’s are running this system, one 914 in progress.
Check it out, sounds good to me, but if you’ve heard anything bad about them let me know. The only real negatives that I have heard so far is; the CPU isn’t waterproof and the 914 guy said that he was having trouble (stock fan) mounting the crank trigger.
6 cylinder version base price $ 815, full meal deal $1320. (full list price, not counting discount)
8 cylinder and Mazda 2 rotor systems also available.
If anyone is interested shoot me an email. I’m thinking about buying at the end of April/May.
mhenry69@sympatico.ca
JeffBowlsby
post Mar 3 2003, 11:05 AM
You might get around this mounting it in an old d-jet ECU case, but the next question is will this affect its heatsink abilities?
Dont know frankly. I might look at mounting the new ECU in the original ECU box, but you might have to cut out access holes (at the bottom of the original ECU box) to install the plug connectors into the new ECU, if my understanding of the SDS boxs' dimensions and plugs are right. The oversized hole could allow adequate ventialtion and still give water protection.
ANother location might be to mount the new ECU on the sloped surface at the rear of the rear trunk (towards the front of the car).
I studied the wiring schematics...a new harness could be made to use the fuel pump relay and connections off the stock relay plate. Aside from abandoning the MPS, I think the install could almost be a perfect sleeper and look almost completely stock.
Mark Henry   GROUP BUY Programmable electronic fuel injection (   Feb 27 2003, 02:21 PM
914Timo   Good idea and very nice system, but I like more fi...   Feb 28 2003, 01:43 AM
Mark Henry   Timo, that system still requires a laptop computer...   Feb 28 2003, 05:23 PM
Mueller   I looked at the SDS system, but me being me (cheap...   Feb 28 2003, 05:36 PM
Mark Henry   When is Mega squirt going to be available next? ...   Feb 28 2003, 05:42 PM
Mueller   Not sure when the next group buy is....soon I woul...   Feb 28 2003, 05:55 PM
Jeff Bowlsby   I think the SDS system is a great candidate for so...   Feb 28 2003, 06:44 PM
airsix   Don't rule out systems that need a laptop...   Feb 28 2003, 06:44 PM
Mark Henry   Bowlsby gave this system a thumbs up, (I think ;)...   Feb 28 2003, 10:59 PM
Jeff Bowlsby   Yesm, that was my official thumbs up on the SDS. ...   Mar 1 2003, 12:27 AM
jonwatts   I'm not knocking this system because I haven...   Mar 1 2003, 12:34 AM
airsix
  Mar 2 2003, 11:23 AM
airsix   Mueller is right. PEFI is great. I am very glad ...   Mar 2 2003, 11:54 AM
Alfred   Does anyone have experience with the CB Performanc...   Mar 2 2003, 12:22 PM
Mark Henry   This is the links to the compatition, most won...   Mar 2 2003, 12:39 PM
Mark Henry   IMHO the CB system sucks, it isn't even in the...   Mar 2 2003, 12:51 PM
Mueller   Why are people so hung up on the wiring harness? ...   Mar 2 2003, 01:05 PM
Jeff Bowlsby   A stock DJet FI harness takes ME most of a day to ...   Mar 2 2003, 01:37 PM
Mark Henry   basic system FI only   Mar 2 2003, 01:59 PM
Jeff Bowlsby   "The EM-4 ECU uses 4 connectors arranged on one si...   Mar 2 2003, 02:19 PM
Mark Henry   Jeff, One thing I also noticed was they don't...   Mar 2 2003, 05:24 PM
jonwatts   Mount the ECU in a rubbermaid food storage box (I...   Mar 2 2003, 08:27 PM
chunger   MS system is fun. . . Having no experience solder...   Mar 3 2003, 02:56 AM
914Timo   I have soldered quite a many circuit boards and wo...   Mar 3 2003, 03:22 AM
Jeff Bowlsby
airsix   Heat dissipation is definitely an issue. The litt...   Mar 3 2003, 11:44 AM
Mueller   I mounted my MS ECU in the rear trunk with the wir...   Mar 3 2003, 12:26 PM
Mark Henry   I posted the group buy offer over on the STF, we n...   Mar 3 2003, 03:06 PM
Mark Henry   We now have 4 people interested, that's good f...   Mar 4 2003, 01:47 PM
street legal go-kart   almost a month later is anyone still watching this...   Mar 28 2003, 10:17 PM
Mark Henry   We have 8 people on the list. B) I moved it over...   Mar 28 2003, 10:55 PM
Dave_Darling   Technically the SDS or anything that is not stock ...   Mar 28 2003, 11:27 PM
Mueller   Mark, The SDS guy was lying to you about the smog...   Mar 28 2003, 11:32 PM
Mark Henry   I kind of figured that this was the old “Le...   Mar 29 2003, 10:30 AM
Mark Henry   RE: SDS group buy OK, it’s not that long t...   Apr 6 2003, 02:35 PM
Mark Henry   OK, I’ve made the call on the STF for all th...   Apr 8 2003, 11:33 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 04:13 PM
