| nycchef |
Aug 10 2006, 09:52 AM
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
o.k. it's been 2 weeks without a problem so i guess i was do. small wisp of smoke from around the fuse box only when i start the car for the first time. pull over leave the car running and its gone before i can find it. nothing hot or melting, all obvious elec working. probably not goin to fix itself. any ideas guys .P.S. the fuel pump is hot wired to the coil but its been that way since the po and i am going to try and fix it
| ptravnic |
Aug 10 2006, 10:11 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,231 Joined: 27-May 03 From: Chicago, IL Member No.: 747 Region Association: None
Eectrical gremlins can be madening to track down. Drop the fuse box, start the car and poke your nose in there to see if you can spot the smokey area. Other than that, replace the box w/Engman's kit & hope the problem goes away...
nycchef elec fire is this bad? Aug 10 2006, 09:52 AM
Sammy Inspect every wire. If it got hot enough to let th... Aug 10 2006, 10:59 AM
bondo Sure it's electrical? I've had smoke from ... Aug 10 2006, 10:59 AM
Sammy Here's a very usefull website that details Luc... Aug 10 2006, 11:02 AM
nycchef definately electrical know that smell. will check ... Aug 10 2006, 11:30 AM
ClayPerrine Positive ground depends upon proper circuit functi... Aug 10 2006, 11:28 AM
ClayPerrine Bell Labs Proves Existence of Dark Suckers
For ye... Aug 10 2006, 11:33 AM
Sammy Nycchef, please don't take any of this lucas s... Aug 10 2006, 11:51 AM
Sammy Q. If, as you say, light bulbs suck up darkness a... Aug 10 2006, 11:54 AM
nycchef thanks for letting me in on the joke. i wasn't... Aug 10 2006, 02:32 PM
Joe Sharp ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:53 AM |
