| nycchef |
Aug 10 2006, 09:52 AM
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None |
o.k. it's been 2 weeks without a problem so i guess i was do. small wisp of smoke from around the fuse box only when i start the car for the first time. pull over leave the car running and its gone before i can find it. nothing hot or melting, all obvious elec working. probably not goin to fix itself. any ideas guys .P.S. the fuel pump is hot wired to the coil but its been that way since the po and i am going to try and fix it
| Sammy |
Aug 10 2006, 11:54 AM
. ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 21-January 03 From: Orange, Ca Member No.: 178 |
Q. If, as you say, light bulbs suck up darkness and convert it to smoke which is transmitted (via wire) to a power source for recycling...why do car batteries go dead when lights are left on? Do car batteries (and flashlight batteries for that matter) have a limited amount of storage capability? Is it like a hard drive that gets so full that you have to double-space and then lose all data? A. Of course the battery stores the smoke. In fact it can store so much smoke that if you open the top and light a match, the resulting explosion can do serious damage. I'm sure you are aware that usually where there's smoke there's fire. If you connect the battery to a charger, the smoke is then returned to the wire (Remember, a light bulb wont work unless it is connected to a wire system) for the utility companies to use. Your hard drive analogy is a very good example. |
| nycchef |
Aug 10 2006, 02:32 PM
thanks for letting me in on the joke. i wasn't sure if i was really dumb or you guys were really nuts. now i know it's a little of both. this is the best non-club a non member could ever hope for.
nycchef elec fire is this bad? Aug 10 2006, 09:52 AM
ptravnic Eectrical gremlins can be madening to track down. ... Aug 10 2006, 10:11 AM
Sammy Inspect every wire. If it got hot enough to let th... Aug 10 2006, 10:59 AM
bondo Sure it's electrical? I've had smoke from ... Aug 10 2006, 10:59 AM
Sammy Here's a very usefull website that details Luc... Aug 10 2006, 11:02 AM
nycchef definately electrical know that smell. will check ... Aug 10 2006, 11:30 AM
ClayPerrine Positive ground depends upon proper circuit functi... Aug 10 2006, 11:28 AM
ClayPerrine Bell Labs Proves Existence of Dark Suckers
For ye... Aug 10 2006, 11:33 AM
Sammy Nycchef, please don't take any of this lucas s... Aug 10 2006, 11:51 AM
Joe Sharp ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:52 AM |
