> Stupid question How do I put oil in my transmission?
Greg Bell
post Aug 12 2006, 12:15 PM
I am embarrassed to say, I have no idea how to put oil in my transmission.
GHB
Sammy
post Aug 12 2006, 01:35 PM
Easiest way to do it?
Pull the fill plug first (as previously mentioned).
Pull the drain plug, drain old oil (don't get it in your hair).
Put the drain plug back in. Leave the drain pan under tranny.
Hang a funnel on your door handle, roof, window, whatever with a piece of metal coathanger wire.
Connect the funnel to the tranny fill port with a piece of plastic hose.
Pour oil into the funnel slowly, stop when you see oil coming out of the fill plug hole. Gravity is your friend.
Let it drain until it stops, re-install fill plug.
Greg Bell   Stupid question How do I put oil in my transmission?   Aug 12 2006, 12:15 PM
Mueller   there will be plug on the passanger side, use the ...   Aug 12 2006, 12:21 PM
Aaron Cox   the 1 quart pointy bottles will get it in there no...   Aug 12 2006, 12:23 PM
mikez   BEFORE DRAINING....make sure you can open the fill...   Aug 12 2006, 12:39 PM
Cap'n Krusty   When you do get the fill plug out, remember TWO th...   Aug 12 2006, 12:49 PM
Greg Bell   Thanks guys!!   Aug 12 2006, 01:10 PM
Sammy   Easiest way to do it? Pull the fill plug first (a...   Aug 12 2006, 01:35 PM
WildBill   If you can't find that giant allen wrench loca...   Aug 12 2006, 04:48 PM
Aaron Cox   your vw shop will have 17mm allen sockets... bugs...   Aug 12 2006, 04:51 PM
Greg Bell   Thanks, Allright, I picked up a big ol' 17mm ...   Aug 12 2006, 05:25 PM
Rand   Yes, the Castrol GL5 is good. Some people swear by...   Aug 12 2006, 05:38 PM
Cap'n Krusty   The stuff on the drain plug is normal. Looks like...   Aug 12 2006, 05:56 PM
Greg Bell   My transmission works fine--for the first 5-10 min...   Aug 12 2006, 06:05 PM
jwalters
- Lo-Fi Version Time is now: 3rd July 2025 - 05:11 PM
