> Cylinder Head Temperature Sensor, Electrical Characteristics ??
mnementh
post Aug 16 2006, 06:50 PM
Hello All,
I hope someone can help me out a little bit. Does any one know the electrical characteristics of the cylinder head temperature sensor ? As in what is the resistance range over a given temperature range ? I know the resistance goes down as the temperature goes up. Also, as the temperature increases, does this sensor enrich or derich the fuel mixture ? I am looking to bias my sensor a little to try and correct a wicked rich condition. Thanks for any info you may have.
jhadler
post Aug 16 2006, 06:58 PM
Long term tinkerer...
I don't remember the resistance values off the top of my head...
The resistance drops as it heats up (thermistor). It's designed for enrichment when themotor is cold. So as the engine heats up, and the resistance drops, the ECU leans out the mixture. A common "patch" is to place a 270 ohm resistor in-line with the HTS to richen the mixture up a little.
-Josh2
mnementh   Cylinder Head Temperature Sensor   Aug 16 2006, 06:50 PM
jhadler   I don't remember the resistance values off the...   Aug 16 2006, 06:58 PM
Mueller   here you go.... L-Jet troubleshooting and info   Aug 16 2006, 06:58 PM
mnementh   Josh and Mueller, Outstanding, Thanks for the...   Aug 17 2006, 02:27 PM
ptravnic   Check w/ Drewvw He's done some resistor modi...   Aug 17 2006, 02:30 PM
Cap'n Krusty
- Lo-Fi Version Time is now: 6th July 2025 - 11:03 AM
