1.7L running rough in the mid RPMs, Potential Causes of rough running (MIDS) |
scwade |
Oct 12 2003, 08:43 PM
Newbie Group: Members Posts: 10 Joined: 31-August 03 From: santa clara, ca Member No.: 1,091 |
I have a 1971 1.7L (with big bore kit) running FI. I'm having some odd behavior between 4,000-4,300 RPM. It runs rough at that RPM regardless of gears/speed.
I've checked timing at 3,500 (fine). I've swapped spark plugs (bosh) // got rid of some pre-detination ping, but still have the roughness (cutting out) I've put in 91 octane (best I can get here in CA) Still happens. PS - it idles rough as well. When I remove the "retardation" line it idles fine. I've not tried to run it full boar with no retardation though. Any ideas? Scott |
Bleyseng |
Oct 19 2003, 01:00 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Can't adjust the computer. You can adjust the fuel pressure and the MPS.
First things first, always look at mechanical parts for the problem. A bad dizzy is the first. How does it drive at 2500-3000 rpms? Smooth or bucks, mis-fires? How about WOT? Geoff |
Lo-Fi Version | Time is now: 9th June 2024 - 03:48 PM |
