| Mike T |
Sep 1 2006, 04:23 PM
can't 'member ![]() ![]() Group: Members Posts: 378 Joined: 16-January 03 From: Brackney, PA Member No.: 161 |
After a dismal performance plagued by random oversteer at my last AX I decided to that continuing to use the car in it's current state made no sense. I have been accumulating a bunch of suspension pieces and fiberglass body parts and decided that there was no time like the present to get to work.
This was the car on July 16th; Attached image(s)
| Mike T |
Sep 1 2006, 04:36 PM
I began with the Bushing install.
PolyBronze bushing kit comes with bushings to do both front A-arms and both rear control arms, shims and intructions. Attached thumbnail(s)
Mike T PolyBronze Bushing Install and other modifications. Sep 1 2006, 04:23 PM
Mike T The PolyBronze Front Bushings come with 3 thicknes... Sep 1 2006, 04:38 PM
Mike T Here I'm using a .001" and a .002" s... Sep 1 2006, 04:41 PM
Mike T The finished installation.
I let it set up overni... Sep 1 2006, 04:47 PM
Mike T When I removed the rear trailing arms I found this... Sep 1 2006, 04:51 PM
Mike T The trailing arm and all the parts to install the ... Sep 1 2006, 05:01 PM
Mike T Measure over 15/16", drill straight and you n... Sep 1 2006, 05:31 PM
Mike T I moved on to the chassis work. A few years ago I ... Sep 1 2006, 05:45 PM
Mike T With the rear tail light panel cut away along with... Sep 1 2006, 05:50 PM
Mike T I repaired the bent nose by cutting away all the s... Sep 1 2006, 06:03 PM
Mike T I replaced the entire front fender because it had ... Sep 1 2006, 06:20 PM
Mike T Here are the Weltmeister Polygraphite bushings I t... Sep 1 2006, 06:38 PM
J P Stein I'm prolly movin' to E Mod. Glad you doan ... Sep 1 2006, 06:45 PM
trekkor Thanks for posting. Glad to see a project moving f... Sep 1 2006, 07:21 PM
URY914 Great thread and great job, Tim.
Your front trun... Sep 1 2006, 08:03 PM
Mike T Last Wednesday I bought a set of the lever arm sty... Sep 12 2006, 06:36 PM
914forme :popcorn: Let us know!!!! Sep 13 2006, 08:21 AM
Mike T Just an update on my project. I received the scale... Oct 3 2006, 05:22 PM
Mike T Another update on the work I did to my car.
I us... Oct 12 2006, 11:24 AM
URY914 1820! What a PIG! :lol: But I suppose a V... Oct 12 2006, 12:05 PM
Mike T I know, I know... I was sort of dissapointed with ... Oct 12 2006, 05:23 PM
URY914 I hear ya about the driver's weight. :(
I dr... Oct 12 2006, 08:55 PM
Rough_Rider So Mike,
What the skinny on those scales? Are they... Oct 13 2006, 04:43 PM
Mike T I think they work pretty well. Easy to use. Strong... Oct 13 2006, 07:41 PM
914forme You could allways change your block, Donovanmakes ... Oct 13 2006, 08:32 PM
Mike T I intended to put pics of the scales and weighing ... Nov 6 2006, 07:36 AM
URY914 ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:15 PM |
