| Mike T |
Sep 1 2006, 04:23 PM
can't 'member ![]() ![]() Group: Members Posts: 378 Joined: 16-January 03 From: Brackney, PA Member No.: 161 |
After a dismal performance plagued by random oversteer at my last AX I decided to that continuing to use the car in it's current state made no sense. I have been accumulating a bunch of suspension pieces and fiberglass body parts and decided that there was no time like the present to get to work.
This was the car on July 16th; Attached image(s)
| Mike T |
Sep 1 2006, 04:38 PM
The PolyBronze Front Bushings come with 3 thicknesses of steel shim stock to be used to take up any play when fitting up the inner race sleeve on the control arm. .001" .002", .004"
The bushings are marked for "front" and "rear" meaning the front of the control arm and the rear of the control arm. Don't mix them up. Attached thumbnail(s)
Mike T PolyBronze Bushing Install and other modifications. Sep 1 2006, 04:23 PM
Mike T I began with the Bushing install.
PolyBronze bush... Sep 1 2006, 04:36 PM
Mike T Here I'm using a .001" and a .002" s... Sep 1 2006, 04:41 PM
Mike T The finished installation.
I let it set up overni... Sep 1 2006, 04:47 PM
Mike T When I removed the rear trailing arms I found this... Sep 1 2006, 04:51 PM
Mike T The trailing arm and all the parts to install the ... Sep 1 2006, 05:01 PM
Mike T Measure over 15/16", drill straight and you n... Sep 1 2006, 05:31 PM
Mike T I moved on to the chassis work. A few years ago I ... Sep 1 2006, 05:45 PM
Mike T With the rear tail light panel cut away along with... Sep 1 2006, 05:50 PM
Mike T I repaired the bent nose by cutting away all the s... Sep 1 2006, 06:03 PM
Mike T I replaced the entire front fender because it had ... Sep 1 2006, 06:20 PM
Mike T Here are the Weltmeister Polygraphite bushings I t... Sep 1 2006, 06:38 PM
J P Stein I'm prolly movin' to E Mod. Glad you doan ... Sep 1 2006, 06:45 PM
trekkor Thanks for posting. Glad to see a project moving f... Sep 1 2006, 07:21 PM
URY914 Great thread and great job, Tim.
Your front trun... Sep 1 2006, 08:03 PM
Mike T Last Wednesday I bought a set of the lever arm sty... Sep 12 2006, 06:36 PM
914forme :popcorn: Let us know!!!! Sep 13 2006, 08:21 AM
Mike T Just an update on my project. I received the scale... Oct 3 2006, 05:22 PM
Mike T Another update on the work I did to my car.
I us... Oct 12 2006, 11:24 AM
URY914 1820! What a PIG! :lol: But I suppose a V... Oct 12 2006, 12:05 PM
Mike T I know, I know... I was sort of dissapointed with ... Oct 12 2006, 05:23 PM
URY914 I hear ya about the driver's weight. :(
I dr... Oct 12 2006, 08:55 PM
Rough_Rider So Mike,
What the skinny on those scales? Are they... Oct 13 2006, 04:43 PM
Mike T I think they work pretty well. Easy to use. Strong... Oct 13 2006, 07:41 PM
914forme You could allways change your block, Donovanmakes ... Oct 13 2006, 08:32 PM
Mike T I intended to put pics of the scales and weighing ... Nov 6 2006, 07:36 AM
URY914 ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:15 PM |
