> started first real work on my 71, bodywork....Yay!!!
geniusanthony
post Sep 9 2006, 07:10 PM
Its a brand new "Chrome-sicle"
started out by stripping all four corners about a month ago, then bought my fuches, but since then I have kinda stalled out mostly due to work obligations, had to go to NE Washington for the forest fires for the last three weeks or so.
before I left I bought 16x6 and 7's and found that some stretching would be necessary in the rear. I have always liked soft flares anyway... but as follows is 1) as delivered
2-4) stripped and pounding started on the rear fenders
John Kelly
post Sep 10 2006, 07:20 AM
Hi Tony,
You need to use a hammer and dolly to smooth the lumps before anymore stretching. If you choose a dolly that has slightly less curve up and down than the fender will when finished, you will find that it will help reduce the up and down curve and give you more curve front to back. The dolly must be flat side to side. This is critical to making a good flare.
The hammer should be wide and smooth with soft edges. Or invest in a slapper or slap hammer from Ron Covell at: www.covell.biz You can also make your own. A much more efficient tool than a hammer.
Start out with medium hard blows with a hammer while pushing out with the dolly from behind. As the metal gets less lumpy, you will have to hit harder and push the dolly out with more force to get the metal smooth. This is a lot of work. Don’t stop until the metal is a lot smoother. It can still have small discrepancies when you stop hammering, just not too wavy or lumpy. Then you can do another round of stretching and repeat.
Stay at least 2” away from the wheel opening with your stretching so that that it does not get too distorted. I don’t remember if you have my video or not, but here is my album with pictures of the tools:
http://allshops.org/cgi-bin/community/comm...d=9980138836765
Since I put the album together I have made another smoothing clamp that is flatter and wider. You can run it front to back on the flare and it will also help reduce the up and down curve.
John www.ghiaspecialties.com
geniusanthony   started first real work on my 71   Sep 9 2006, 07:10 PM
geniusanthony   #2 stretched   Sep 9 2006, 07:15 PM
geniusanthony   #3 close up on fender   Sep 9 2006, 07:16 PM
JPB   Lots of stroking on that sheet metal bro. Good wo...   Sep 9 2006, 07:21 PM
geniusanthony   #4 close up again...and problem area which i need ...   Sep 9 2006, 07:23 PM
geniusanthony   dont worry i know i am not close to being done (bu...   Sep 9 2006, 07:28 PM
Lou W   Looking good, looks like you'll end up with so...   Sep 9 2006, 07:34 PM
geniusanthony   my goal is more rounded to flow into the shoulders...   Sep 9 2006, 07:54 PM
Lou W   No, its not mine...however there are people here t...   Sep 9 2006, 07:57 PM
geniusanthony   BUMP   Sep 10 2006, 04:37 AM
JPB   If you use a brazing tip on a torch and the samlle...   Sep 10 2006, 06:14 AM
John Kelly   Hi Tony, You need to use a hammer and dolly to sm...   Sep 10 2006, 07:20 AM
geniusanthony   John, thank you for your quick reply to my earlier...   Sep 12 2006, 03:26 AM
geniusanthony   side note all I am trying to intall in the rear is...   Sep 12 2006, 10:24 PM
John Kelly   Hi Tony, It takes many stretch and smooth session...   Sep 13 2006, 08:06 AM
geniusanthony   haven't had the oppportunity to wokr lately or...   Sep 14 2006, 08:50 AM
John Kelly
- Lo-Fi Version Time is now: 5th March 2026 - 12:12 AM
