I hate my engine, Love the rest of the 914 |
Andyrew |
Oct 22 2003, 06:00 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
I am begining to hate my engine, I cant figure out the problems, and more syptoms are starting to appear!!
For starters, I have had to replace the fuel pump fuse 2 times in the last two days.. Both times I was stranded in the road.. Luckly I had enough sense today to take one of the ones from a light. Next Im having power surges, asside from having almost no power.. I am still having a high idle problem and I still cant get the electronic ignition to work.. ARGG! |
Kevin@ojai.net |
Oct 23 2003, 12:39 AM
Member Group: Members Posts: 158 Joined: 9-July 03 From: Ventura & Chico, CA Member No.: 899 |
You should fix that vacuum leak from the runners... As for your popping fuse, obviously something is grounding out some place; start looking for stray wires. It might be a good idea to pull your injectors and make sure none are leaking and all have a good spray pattern. Also, it goes with out saying to make sure the engine is in good health (valve adjustment, compression, ect.). Good luck.
-Kevin |
Lo-Fi Version | Time is now: 11th June 2024 - 05:45 PM |
