"Tubbed" trailing arms, Pics |
914Timo |
Mar 5 2003, 02:47 AM
******* Group: Members Posts: 743 Joined: 13-January 03 From: Finland Member No.: 137 Region Association: Europe |
If you remember, I send some pics about my trailing arms a couple of months ago. Then I had just moved the bearing housing 15 mm inwards. After those pics I have sandblasted them, done all modifications for 911 e-brakes and painted them. Hope you will like the pics.
Brad Roberts |
Mar 5 2003, 02:53 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
They look nice. Did you ad some more negative camber to them while you had them cut apart ?
It appears that the mods where: addition of tab for 911 cable or housing. Now that you have modified the bearing holder, will you shorten the axles (or use the early 911 setup) ?? which would workout just right. The 15mm: Will you cut the inner fenderwell to put more tire under it ? Explain to us the benefit of cutting the control arms this way (the best you can) B |
Lo-Fi Version | Time is now: 7th June 2024 - 04:01 AM |
