| grantsfo |
Sep 20 2006, 10:14 AM
Arrrrhhhh! ![]() ![]() ![]() ![]() Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
My original 901 (never been rebuilt) tranny lost second gear. So I have found a loaner 901 transmission while I have mine rebuilt. I'm going to go for shorter gears. Can somone help educate me to options around shorter gears for a 901 transmission. I'm having a shop do the work but I want to educate myself to what track drivers think works best for gears. I have a 2.4 that makes something around 160 to 170 HP and use 265/45/16 tires in the rear. I will mostly be just having fun doing track days.
| brant |
Sep 20 2006, 10:19 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,282 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
grant,
it depends upon the track length and your powerband. without going to a dyno you would need to calculate your top speed at the longest straight and then calculate that to 5th gear. then once you have a 5th gear picked out you work backwards from there to equalize the gaps between each respective lower gear. of course aerodynamic drag plays into it and you can have bigger gaps between the lower gears than you should have between the top gears. finally the next factor is cost. Some gear ratios cost 50 bucks and others cost 800$. So it becomes necessary that if a certain ratio is perfect but the next closest thing is 600 cheaper you might use the compromise ratio. in the end. people will tell you to go msx but that doesn't mean it is actually the fastest option. just simple. I found my car to be faster by using lower ratio's than msx I will have those 3 ratios available for sale soon as used. brant |
grantsfo Shorter gears for 901 Sep 20 2006, 10:14 AM
grantsfo What is MSX? That is what was being reccomended to... Sep 20 2006, 10:53 AM
North Bay 914 I agree, M,S,X. the letter codes for the ratios 3,... Sep 20 2006, 11:13 AM
grantsfo Thanks! Sep 20 2006, 11:30 AM
trekkor Grant, I wish you would have rode along during tha... Sep 20 2006, 11:44 AM
race914 Hi Grant,
I have a MSX box and it is great for Th... Sep 20 2006, 12:58 PM
race914 Grant,
Just want to acknowledge again all of the ... Sep 20 2006, 01:17 PM
brant I failed to mention also that your redline is goin... Sep 20 2006, 01:25 PM
trekkor Wow!! That FJOSV gear set sounds like the ... Sep 20 2006, 01:48 PM
brant ![]() ![]() |
Lo-Fi Version | Time is now: 23rd October 2026 - 06:13 PM |
