1.7L running rough in the mid RPMs, Potential Causes of rough running (MIDS) |
scwade |
Oct 12 2003, 08:43 PM
Newbie Group: Members Posts: 10 Joined: 31-August 03 From: santa clara, ca Member No.: 1,091 |
I have a 1971 1.7L (with big bore kit) running FI. I'm having some odd behavior between 4,000-4,300 RPM. It runs rough at that RPM regardless of gears/speed.
I've checked timing at 3,500 (fine). I've swapped spark plugs (bosh) // got rid of some pre-detination ping, but still have the roughness (cutting out) I've put in 91 octane (best I can get here in CA) Still happens. PS - it idles rough as well. When I remove the "retardation" line it idles fine. I've not tried to run it full boar with no retardation though. Any ideas? Scott |
garyh |
Oct 26 2003, 09:34 AM
Member Group: Members Posts: 170 Joined: 8-January 03 From: San Mateo, CA Member No.: 114 |
QUOTE(scwade @ Oct 25 2003, 08:08 PM) The new rotor was no good (couldn't get stable dwell readings) so I used the old rotor and set the dwell to 45 (best I could get to). Cheers, Scott Umm... The rotor has nothing to do with the dwell. The point gap controls the dwell. If changing the rotor affects the dwell, you have other problems going on. G. |
Lo-Fi Version | Time is now: 9th June 2024 - 11:22 PM |
