Alloy brake caliper rebuild ?, What am I doing wrong? |
Eddie Williams |
Oct 26 2003, 11:49 PM
Senior Member Group: Members Posts: 822 Joined: 30-December 02 From: Nederland, TX Member No.: 55 Region Association: None |
When rebuilding Alloy S calipers, what is the trick to getting the piston back in the bore? I put the springs back in the SS pistons, but can only seem to get the piston 1/4 of the way in. I used a clamp to apply pressure and the piston goes in, but as soon as the clamp is removed, the spring back out. What am I doing wrong?
J P Stein |
Oct 27 2003, 11:37 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
They do flex.....dunno about "big time". I'll have to measure it some day.
The main result is a softer brake pedal. This actually has an advantage (or so it seems) during the quick paced action of AX when overexurberant braking can result in locking the front tires.....kind of an automatic "smoothly roll on the brakes" sort of thing...it's about the only thing I do smoothly (IMG:style_emoticons/default/laugh.gif) They ARE a bitch to bleed, tho. |
Lo-Fi Version | Time is now: 11th June 2024 - 09:48 PM |
