Houston... we have a problem. Could be the end of my FFC run, not sure what to look at now |
tdgray |
Oct 3 2006, 07:38 AM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
OK so last weekend I changed out my injectors with some known good injectors. The old ones looked very bad and I was thinking that they were the cause of my running rich. I also went back to a colder plug (NGK) as I was worried about running the Bosch Plats figuring they were too hot.
Well it appears that did not fix the problem. I think I loaded up the plugs again (wife is bringing SP wrench and old plats to me at lunch time). Car was bucking and missing all over the place. Barely made it to work. All wires are connected injectors firing good spark to all cylinders etc. If I can't figure this out I am not going to risk a 200 + mile trip. Here is what I know is good or what I've done do far. MPS is good - holds vac rebuilt by Geoff. Cold start valve unhooked and bypassed Injectors changed to known good injectors. All vac hoses are brand new. Ignition is pertronix with a pertonix coil. Car starts up immediatley. Good fuel pressure - right at 29 lbs. Inline gauge never waivers. What am I missing... this thing is still puking black smoke occasionally and smells very rich. Where should I look now. (IMG:style_emoticons/default/confused24.gif) |
tdgray |
Oct 3 2006, 08:27 AM
Good suggestion Britt.
Thats one place I have not looked at yet. PM coming. Another thought... I adjusted the valves when I have the motor out of the car. I used the Capn's method. Could I have F'd the procedure up and could this make the car run like this? I'm graspings here I know. Oh and other things. Timing is dead on. Idles at 850-900 like it should. |
Bartlett 914 |
Oct 3 2006, 09:23 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Good suggestion Britt. Thats one place I have not looked at yet. PM coming. Another thought... I adjusted the valves when I have the motor out of the car. I used the Capn's method. Could I have F'd the procedure up and could this make the car run like this? I'm graspings here I know. Oh and other things. Timing is dead on. Idles at 850-900 like it should. I don't think that valve adjustment will make it run rich but I could be wrong. If in doubt, do a compression check. I adjusted my valves on Sunday because I had the HE's off. I wanted to use some of the methods that were suggested. I still found the simplest method was to remove the plugs rotate the motor until a valve was fully depressed and then adjust the opposite valve. With out the plugs, the motor turns easy and you only look at one thing at a time. It just means more cranking. I am 90 percent ready for FFC. I hope to see you there Mark Mark |
Lo-Fi Version | Time is now: 10th June 2024 - 07:24 AM |
