Yet another electrical problem, erratic flashers, with a twist |
scottz0369 |
Oct 5 2006, 10:52 PM
Newbie Group: Members Posts: 23 Joined: 30-September 05 From: 29 Palms, CA Member No.: 4,894 |
Here's one I couldn't find with a search---
I think I have a flasher relay problem, but I'm not positive--My blinkers/brake warning light flash extremely rapidly and erratically--sounds like a relay issue except for this--they work just fine when I have jumper cables attached. The battery was completely dead yesterday (one minute after starting normally). One minute the car turned over fine, the next there wasn't even a click. After I jumped it is when I got the flashing problem. I'm not sure if this is one problem, or many. My battery reads 10.6 volts at the terminals--driving it for a half-hour at speed didn't do a darn thing for it. It has been sitting since February, so it may well be a bad battery. The auto shop on base here will have a new battery tomorrow for me, and with luck, the local auto shop (there's not much out here--29 palms is the end of the road) will have a relay. I hope the battery/relay are two seperate problems that happened to come up at the same time, but I'm suspicious of the timing...... ah, the adventure of having a 34 year old car. There's never a dull moment! Scott |
Dr Evil |
Oct 6 2006, 02:40 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Clean, clean, clean your connections. Sounds like you have intermittant grounds all over. Check the tranny ground strap and its connections, engine connections, etc.
Lo-Fi Version | Time is now: 11th June 2024 - 12:13 AM |
