Yet another electrical problem, erratic flashers, with a twist |
scottz0369 |
Oct 5 2006, 10:52 PM
Newbie Group: Members Posts: 23 Joined: 30-September 05 From: 29 Palms, CA Member No.: 4,894 |
Here's one I couldn't find with a search---
I think I have a flasher relay problem, but I'm not positive--My blinkers/brake warning light flash extremely rapidly and erratically--sounds like a relay issue except for this--they work just fine when I have jumper cables attached. The battery was completely dead yesterday (one minute after starting normally). One minute the car turned over fine, the next there wasn't even a click. After I jumped it is when I got the flashing problem. I'm not sure if this is one problem, or many. My battery reads 10.6 volts at the terminals--driving it for a half-hour at speed didn't do a darn thing for it. It has been sitting since February, so it may well be a bad battery. The auto shop on base here will have a new battery tomorrow for me, and with luck, the local auto shop (there's not much out here--29 palms is the end of the road) will have a relay. I hope the battery/relay are two seperate problems that happened to come up at the same time, but I'm suspicious of the timing...... ah, the adventure of having a 34 year old car. There's never a dull moment! Scott |
So.Cal.914 |
Oct 6 2006, 05:21 PM
"...And it has a front trunk too." Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None |
Your voltage is to low, one thing you can do to check your alt is jump the car,
and then disconnect the pos (+) side of the battery. If it continues to run it is working, change battery and test again. Should show between 13 & 15 volts. Then try your flashers, My guess is they will work as normal. |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:27 AM |
