| mtrotter |
Oct 8 2006, 09:55 AM
Newbie ![]() Group: Members Posts: 23 Joined: 24-June 06 From: Temecula Member No.: 6,299 |
http://www.jegs.com/webapp/wcs/stores/serv...ategoryId=12929
Im thinking they will work with... the stock perches.... any thoughts? |
drew365 What is the diameter of the springs? If they are 2... Oct 8 2006, 10:46 AM
URY914 You need to know the inside and outside diameters ... Oct 8 2006, 10:49 AM
914forme I am taking a set out of my car today, I will let ... Oct 8 2006, 11:35 AM
nebreitling those won't work unless you have aftermarket p... Oct 8 2006, 01:11 PM
Aaron Cox yep... 2.5 X length.. works with aftermarket perch... Oct 8 2006, 03:31 PM
914forme Stock Shock cap is ~4"
Stock Spring Inside is... Oct 8 2006, 03:37 PM
914forme I added some 2.5" spacers to keep the springs... Oct 8 2006, 03:40 PM
Aaron Cox why not buy real coilover sleeves from coleman.... Oct 8 2006, 08:58 PM
nebreitling i'm with aaron on that one... a spring that sl... Oct 8 2006, 09:44 PM
Aaron Cox its like 40 bucks per side to do it right......
y... Oct 8 2006, 10:50 PM
914forme I am way ahead of you guys, I ordered them all rea... Oct 9 2006, 09:15 AM
914forme Colemann Parts came in :boing: I am off to the sho... Oct 9 2006, 02:57 PM
J P Stein They can be installed properly (without the hat fl... Oct 9 2006, 04:52 PM
Rough_Rider Mini-tip: Don't wrench the zip ties down tight... Oct 9 2006, 05:22 PM
914forme Okay so did you heat the sleave in the oven or wit... Oct 9 2006, 05:38 PM
J P Stein ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:35 PM |
