| mtrotter |
Oct 8 2006, 09:55 AM
Newbie ![]() Group: Members Posts: 23 Joined: 24-June 06 From: Temecula Member No.: 6,299 |
http://www.jegs.com/webapp/wcs/stores/serv...ategoryId=12929
Im thinking they will work with... the stock perches.... any thoughts? |
| 914forme |
Oct 9 2006, 05:38 PM
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,899 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None
Okay so did you heat the sleave in the oven or with a torch? I used a oven first, and then got 2/3 of the way down, and then it stuck, so I grabbed my tourch.... Okay just to let you know I am classing myself as an Moron!!!! Got it to slip down and then I walked away to let it cool. Cameback an hour latter to find oil all over the floor.
Anybody know how to rebuild a Bilstein sport????? The DIY method would be great. How hot do you heat these to to get them on? My buddy suggesed honning them, press them on, and using red locktight, to set them. Hindsight is 20/20! |
| J P Stein |
Oct 9 2006, 06:25 PM
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Okay so did you heat the sleave in the oven or with a torch? I used a oven first, and then got 2/3 of the way down, and then it stuck, so I grabbed my tourch.... Okay just to let you know I am classing myself as an Moron!!!! Got it to slip down and then I walked away to let it cool. Cameback an hour latter to find oil all over the floor. Anybody know how to rebuild a Bilstein sport????? The DIY method would be great. How hot do you heat these to to get them on? My buddy suggesed honning them, press them on, and using red locktight, to set them. Hindsight is 20/20! Hummm.......no. You need to give the Coleman folks the OD of your socks.....a tad over 2 inches, IIRC. The proper threaded sleeves are about .03/.04 ID larger than the shock. I used plastic shim stock to fill the gap twixt the 2. It appears you have the wrong ones. Bilstein will rebuild/revalve your shocks for 65 bucks + parts. Bilstein West In Poway, CA. 1 800 537 1085 Since one is hosed, you may as well send both & have them revalved. You need to tell them your spring rates & weight of your car and usage (AX?) |
mtrotter has anyone used these springs? Oct 8 2006, 09:55 AM
drew365 What is the diameter of the springs? If they are 2... Oct 8 2006, 10:46 AM
URY914 You need to know the inside and outside diameters ... Oct 8 2006, 10:49 AM
914forme I am taking a set out of my car today, I will let ... Oct 8 2006, 11:35 AM
nebreitling those won't work unless you have aftermarket p... Oct 8 2006, 01:11 PM
Aaron Cox yep... 2.5 X length.. works with aftermarket perch... Oct 8 2006, 03:31 PM
914forme Stock Shock cap is ~4"
Stock Spring Inside is... Oct 8 2006, 03:37 PM
914forme I added some 2.5" spacers to keep the springs... Oct 8 2006, 03:40 PM
Aaron Cox why not buy real coilover sleeves from coleman.... Oct 8 2006, 08:58 PM
nebreitling i'm with aaron on that one... a spring that sl... Oct 8 2006, 09:44 PM
Aaron Cox its like 40 bucks per side to do it right......
y... Oct 8 2006, 10:50 PM
914forme I am way ahead of you guys, I ordered them all rea... Oct 9 2006, 09:15 AM
914forme Colemann Parts came in :boing: I am off to the sho... Oct 9 2006, 02:57 PM
J P Stein They can be installed properly (without the hat fl... Oct 9 2006, 04:52 PM
Rough_Rider Mini-tip: Don't wrench the zip ties down tight... Oct 9 2006, 05:22 PM
J P Stein ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:27 PM |
