Pinion Failure-Why?, Gears in disarray |
groot |
Oct 9 2006, 05:52 PM
Dis member Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
It certainly could be my fault. I didn't check/set/change the pinion depth when I re-assembled this gearbox 2 seasons ago.
At Mid-Ohio this weekend I couldn't catch 5th... which led to pitiful laptimes.... in the first session. So, I adjusted the linkage thinking that the fork just wasn't pushing the engagement ring far enough.... next session, same thing. I didn't take the start and watched from a corner station. So, after that I checked the shift linkage, no major issues. I pulled the shift rod holder to look at the shift forks, again no major problems. So, I decided to pull the gearstack and that's when I noticed the pinion pictured here..... still not sure what the problem was with 5th, but it is probably worn synchros. I rebuilt this gearbox before the start of last season and only refreshed it with parts I had....flipped synchros, better dog teeth, a few gear changes and no bearing changes. I'm only running 150 ponies through this box. It looks like the pinion isn't meeting the ring at the right angle, but I'm just guessing. Does anybody have input???? .............sorry for the crappy pics, my camera wouldn't focus on the part I wanted ot show. Attached image(s) |
Brad Roberts |
Oct 10 2006, 03:43 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
I had to put a tranny cooler on the FP car I support out of NorCal. I also had to stop running Redline synthetic a few years back. We ran 3 different boxes for our 5-6 tracks.
I ran one channel of the data acq to a temp probe in the tranny.. NOT GOOD. It also had a lot to do with the header we ran. The collector and stinger were directly under the tranny. B |
grantsfo |
Oct 10 2006, 04:16 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
I had to put a tranny cooler on the FP car I support out of NorCal. I also had to stop running Redline synthetic a few years back. We ran 3 different boxes for our 5-6 tracks. I ran one channel of the data acq to a temp probe in the tranny.. NOT GOOD. It also had a lot to do with the header we ran. The collector and stinger were directly under the tranny. B Yeah I shot my tranny with pyrometer at Laguna after some fast laps. It was in 260 range. That may have been due to some radiant heat from my headers? |
Lo-Fi Version | Time is now: 10th June 2024 - 04:00 PM |
