Building up a 1.7, Will it hold up? |
Michael J |
Oct 19 2006, 08:32 AM
Welcome to 2007 Group: Members Posts: 268 Joined: 23-November 04 From: Olympia, WA Member No.: 3,166 |
I am looking at another 914 which has a 1.7 that has been built to what the PO told the current owner is a 1972 cc, some sort of mild cam and carbs. The story is that the case had to be machined to get the big bore kit in. I thought that 96mm cyls equalled 1911cc on a 1.7 and didn't need any machine work???. So if this isn't just a story, and I will get to the facts before I part with any $, is the 1.7 case durable enough to withstand higher compression and generally more stress. Even if it makes 100 to 110 HP that is a big increase from stock.
toon1 |
Oct 19 2006, 09:21 AM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
Is there a certain casting # to look for or are the 1.7 cases close to all the same?
slight (IMG:style_emoticons/default/hijacked.gif) sorry, Jake you have mentioned that a real efficiant combo is a 78/90, what about a 71/90 with 1.7 heads. will this work |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:27 PM |
