| bernbomb914 |
Mar 6 2003, 01:50 PM
one of the oldest Farts on this board ![]() ![]() ![]() Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
There are two fittings on the bottom of the tank. Doe's it make any differance which one goes to the fuel pump? Both fittings fit both holes. Is there a surge tank on one of them?
Bernie (IMG:style_emoticons/default/confused24.gif) |
| jtf914 |
Mar 6 2003, 04:04 PM
Member ![]() ![]() Group: Members Posts: 428 Joined: 31-December 02 From: Burlington, CT Member No.: 58 Region Association: North East States |
I'm not sure, based on the year/fuel system, but on the 70 914-6 the two tank openings are different. The opening in the tank for the main line is about 10-12mm, and its large enough for the filter screen to be passed though from the bottom into the tank. The return line opening comes to a point inside the tank, and the opening is only about 3-5mm wide. If the tanks remained the same through out the years and the fuel system changes, then it should be pretty obvious when looking up into the tank which opening is which.
Hope this helps, maybe someone with the same year/fuel system can confirm this for you. |
bernbomb914 Gas tank fittings Mar 6 2003, 01:50 PM
Justin Fischer The main line has mesh screen in the tank, and I b... Mar 6 2003, 02:12 PM
bernbomb914 neather one has a screen anymore. as long as the l... Mar 6 2003, 03:24 PM
Dave_Darling There are baffles around the pickup. I'm not ... Mar 6 2003, 05:15 PM
bernbomb914 my car is a 74 both the return line and the pump ... Mar 6 2003, 11:26 PM
Dave Cawdrey You prolly wont see from the bottom. The baffle s... Mar 7 2003, 12:15 AM
bernbomb914 Where do I get a new screen? do they slid in from ... Mar 7 2003, 12:36 AM
Dave Cawdrey Any VW parts store. Just ask for a petcock valve ... Mar 7 2003, 02:53 AM
bernbomb914 Thanks Korijo :worship:
Bernie :headbanger: Mar 7 2003, 11:14 AM
mr914 Has anyone ever changed their tank fittings over t... Mar 7 2003, 12:09 PM
bernbomb914 I bought the vw filter kit, but both the screen an... Mar 12 2003, 01:04 PM
dgw ![]() ![]() |
Lo-Fi Version | Time is now: 30th May 2026 - 05:54 AM |
