Garage humor, mishaps |
Cruzing |
Oct 24 2006, 12:09 PM
Member Group: Members Posts: 214 Joined: 23-October 06 From: San Diego Member No.: 7,082 |
well I thought I would share a mishap with my 914, embaressing as it maybe.. (IMG:style_emoticons/default/smile.gif)
I was installing the engine on a hoist, dropped down the car to align the mounting holes and rear bracket, engine was placed on stands, leveled out and ready to fit in. I noticed that the engine was not fitting correctley, while I was bumping down the lift, I looked up and saw the front of the car coming off the front lift supports, causing the car to have a very bad tilt, I thought, what the hell is that, walked around to the front of the car and found that the hydrolic jack handle had slip up between the tire and the fender and was starting to push through the top of my fender, which was making the car come off the lift, I said Fu***KI**G D**am sh**i**t AHHHH I checked back quickly to the rear and saw clear and ready to go, so I started to raise the car to get the jack handle out of there, while the car was lifting and my full attention to the front was in place, I was about 4'-0" in the air and looked back and saw that the engine got tangled up with my tie strap and was coming off the stands, now it was dangeling 3'-0" in the air, the front was not clear yet and now I am about to drop my motor.. before I could reload, it droped and bounced, cracked the rear housing, (replaced it) and I have a punch out dent on top of my fender. I took a break, finshed and went to get drunk in which I had nooo problems doing that.. Oh well, hope this not to boring.. (IMG:style_emoticons/default/smile.gif) |
Cruzing |
Oct 24 2006, 03:58 PM
With the remanufactured heads failing three times in a row, I was not at my full potential.. (IMG:style_emoticons/default/smile.gif)
But, with focus in order I can install the motor(only) in 20 min. simple idea really, lining up everything is the hardest, soooo the two front bolt hole on frame I connect tie strap from there to engine mount, each hole up front has its own strap, then at the rear I sling one strap all the way across, holding up the rear of the trans, there are two holes in body frame that I use to latch two. I lower car and tighten straps. raise enough for engine to swing and hang straight down by straps, suspended... put two stand up front, one in rear under trans, readjust and tighten straps, raise car and engine, use adjustable supprt stand, then, one at a time, put in the bolts up front and then do rear mounts, really easy and safe and fast to do, by dangling engine it self aligns. anyway thank you and all is well now... (IMG:style_emoticons/default/smile.gif) pS, this is using a two post hydrolic lift.. |
TheCabinetmaker |
Oct 24 2006, 04:42 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
With the remanufactured heads failing three times in a row, I was not at my full potential.. (IMG:style_emoticons/default/smile.gif) But, with focus in order I can install the motor(only) in 20 min. simple idea really, lining up everything is the hardest, soooo the two front bolt hole on frame I connect tie strap from there to engine mount, each hole up front has its own strap, then at the rear I sling one strap all the way across, holding up the rear of the trans, there are two holes in body frame that I use to latch two. I lower car and tighten straps. raise enough for engine to swing and hang straight down by straps, suspended... put two stand up front, one in rear under trans, readjust and tighten straps, raise car and engine, use adjustable supprt stand, then, one at a time, put in the bolts up front and then do rear mounts, really easy and safe and fast to do, by dangling engine it self aligns. anyway thank you and all is well now... (IMG:style_emoticons/default/smile.gif) pS, this is using a two post hydrolic lift.. sounds complicated and dangerous. Two jack stands under donuts, one jack under motor, and lift. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 04:57 PM |
