Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,827 Joined: 20-October 04 From: Columbia, CA./ Tuolumne Member No.: 2,978 Region Association: Northern California ![]() |
I've lost my steering wheel nut and washer. Is there anywhere local where I can find something as a replacement (I think I read it's 27mm?)? Osh only carries up to M12 sized nuts, local bug shop says they don't have any. Also I think I remember that washer being a special "wavy" kind or something.
Same thing for the nut that holds the clutch pedal tight, lost that too. (IMG:style_emoticons/default/dry.gif) Any idea on size of that? thanks.... |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,200 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
If the "other" nut you've lost is the one on the transmission end of the clutch cable, it's a standard M7 nut. Takes an 11mm wrench, usually. Use two regular M7 nuts and tighten them against each other so they don't "self-adjust" while you're driving.
--DD |
Lo-Fi Version | Time is now: 11th July 2025 - 03:14 AM |
