> Shift Grinding
demitristewart
post Oct 24 2006, 12:03 PM
Howdy everyone. I have a 75 914 I just purchased. Nice and fun little car. I have a problem downshifting into 2nd gear -i hear gears grind. Also, when I'm at a stop and go to put the car in 1st gear, it grinds also.
Any idea what the problem is? The clutch engages all the way down by the floor.
Thanks!
Dr Evil
post Oct 26 2006, 07:53 AM
Send me your transmission!
Hey Man,
You typically adjust at the tranny side. If you are out of thread then you may need to replace teh cable as it is streatched out. The adjuster at the pedal end will only adjust a little. Righ the clutch pedal so that the pedal is being pulled outward and cinch the adjusting nut down on the tranny end. No ttoo far or it will engauge the clutch too soon and wear out your TO bearing.
demitristewart   Shift Grinding   Oct 24 2006, 12:03 PM
blitZ   Hi and Welome. The first thing you may want to do...   Oct 24 2006, 01:08 PM
gary gartner   A clutch adjustment would be first on my list of t...   Oct 24 2006, 01:54 PM
demitristewart   That was a good article. I was thinking the clutc...   Oct 24 2006, 02:11 PM
Dr Evil   If your clutch is not adjusted soon you will be lo...   Oct 24 2006, 02:50 PM
rjames   :agree: If you just got the car I would replace ...   Oct 24 2006, 03:51 PM
ein 6er   check your clutch tube!! :wttc:   Oct 24 2006, 06:24 PM
demitristewart   Thanks for all the feedback. I was under the car ...   Oct 25 2006, 10:15 AM
Tobra   try check this out 914 manuals in PDF I use valv...   Oct 25 2006, 02:03 PM
Dr Evil   90w GL-5 gear oil will do ya just fine.   Oct 25 2006, 02:21 PM
Tobra   I think I probably need to adjust my clutch cable ...   Oct 26 2006, 07:49 AM
Dr Evil   Hey Man, You typically adjust at the tranny side....   Oct 26 2006, 07:53 AM
bd1308   I thought GL-5 would kill a trasmission like this?   Oct 26 2006, 07:54 AM
Dr Evil
- Lo-Fi Version Time is now: 19th July 2025 - 04:27 PM
