> OT - Buying a welder...of some sort
ahdoman
post Oct 29 2006, 04:23 PM
It's phonetic...Ah-D-O-Man (Audioman)
Hey all, I asked my wife (a prolific artist) what she would like for her birthday and she said "a welder"! Seems she wants to do a little metal sculpting. I admit, I could use one also. However, I know nothing about what is out there (brands, types, etc.) and need advice as to what to buy. Since this is a test, it needs to be easier to use but I don't want to rapidly outgrow it. Also, it will probably be just for steel work. Suggestions?
mihai914
post Oct 29 2006, 05:21 PM
If you are going to run it on 120V, there is two choices for good welders, the Lincoln or the Miller.
If you need more juice for thicker stuff, than you can go to the similar 220V models from the same manufacturers, they will be pricier though.
Lincoln
Miller
I bought the Lincoln from this eBay vendor (because it was a little bit less expensive), I think it's the best deal around and the service was excellent, so I can recommend them.
Take your time and see what you actually will do with the welder before commiting.
Don't forget also about the gas bottle, decide if you want to rent one or buy your own and have it filled. If both of you are going to do work, then go for a bigger bottle anyway.
There are less expensive units out there, but parts availability and quality of manufacturing and versatility will not be as good. If you're on a budget try going for a good quality used machine. You may be lucky but from what I saw, the ones on eBay go for a pretty penny and I preferred to put the extra $100 and just buy a new one.
Good luck!
- Lo-Fi Version Time is now: 11th July 2025 - 07:17 AM
