> What octane gas do you run?, Is higher always better ? Or just a waste of $$$
Michael N
post Oct 27 2006, 08:19 PM
Certifiable
I was wondering what most drivers are using in their 914's. 87, 92, 100?
I have heard that in fuel injected cars running with a higher octane gas than they were designed to run at can be a waste of money since they are set up to run on a specific octane and any more is lost. I have a Passat and the manufacture states 92 octane. My truck uses 87 and the dealer said I can do damage by running 92 ( although I have no idea why).
Please set me straight on my ignorance. (IMG:style_emoticons/default/sad.gif)
Jake Raby
post Oct 30 2006, 12:26 PM
Engine Surgeon
As I satated above a couple of times every engine is different and even the climate impacts the fuel that will make your engine run it's best..
I will say that my Pinzgauer military truck is the only vehicle I own that will run its best on 87 octane, thats because it has 7;1 CR and was made to run on anything... I have gotten 2 bad batches of fuel in one year in that vehicle (12000 miles), but have only gotten ONE bad tank in the past 109K in my 912E that runs premimum 90% of the time and at least 89 octane all the time.
Its a gamble every time you pull up to the pump, when you see as many melted pistons as I do from engine teardowns you'd understand why 20 cents a gallon is worth the expense if thats the fuel that your engine runs best on...
I build engines specifically to run on 91-93 octane, many times the added efficiency that I'm able to squeeze from the combo will gain the customer at least 2-3 MPG and thats certainly worth more than 20 cents per gallon-
Michael N   What octane gas do you run?   Oct 27 2006, 08:19 PM
rjames   I always use 91 or better (as suggested on the sil...   Oct 27 2006, 08:28 PM
So.Cal.914   As high as available otherwise it runs like dodo.   Oct 27 2006, 09:25 PM
mikerose
  Oct 28 2006, 11:13 AM
Thorshammer   Many of you know I work in the motorcycle industry...   Oct 28 2006, 01:22 PM
rjames
  Oct 28 2006, 03:25 PM
Jake Raby   Eric, That was an excellent post!   Oct 28 2006, 03:27 PM
Michael N   Thanks for all the input. I have been running 9...   Oct 28 2006, 06:34 PM
Jake Raby   If its been running fine on 91, leave it as is. Hi...   Oct 28 2006, 06:54 PM
Michael N   Thanks :D Now off to do some :driving: :drivi...   Oct 28 2006, 06:57 PM
Crazyhippy   If you put higher octane in.. turn up the boost to...   Oct 28 2006, 07:06 PM
Leo Imperial   Erik, What you posted is interesting. I do not wis...   Oct 28 2006, 09:38 PM
gfulcher   Finding a sunoco with 94 octane ULTRA is like find...   Oct 29 2006, 08:12 AM
shelby/914   No test results, or reems of data, just that my li...   Oct 29 2006, 08:53 AM
effutuo101   How often do the tanks get tested? once a year? I ...   Oct 29 2006, 03:54 PM
Air_Cooled_Nut   My $0.02... Gas is LIGHTER than water. Erik,...   Oct 29 2006, 04:04 PM
swood   finally....some much needed validation in my life....   Oct 29 2006, 04:35 PM
RickS   The owners manual recommends 92. I figured the en...   Oct 29 2006, 10:57 PM
Travis Neff   In my stock injected 2.0 I ran regular (87 in AZ),...   Oct 29 2006, 11:01 PM
fitsbain   Lower octain gas burns hotter and makes more power...   Oct 30 2006, 09:38 AM
D1A3   I run 87 on my stock 2.0 engine as recoemnded by P...   Oct 30 2006, 10:16 AM
Demick   I think the thing to take away from all of this is...   Oct 30 2006, 10:52 AM
Jake Raby   As I satated above a couple of times every engine ...   Oct 30 2006, 12:26 PM
Matt Meyer   On a NEW engine with computer controlled timing an...   Oct 30 2006, 12:54 PM
- Lo-Fi Version Time is now: 7th July 2025 - 02:21 PM
