> Mystery CAM - what can you tell me about this lift and duration
Aaron Cox
post Nov 4 2006, 08:47 PM
Professional Lawn Dart
friend here is buying another friends motor...
we went over and measure lift and duration with a dial indicator and a degree wheel...
cam had overlap (visible - did not measure) which makes me positive its a carb cam...
anyway... the specs (lift is +/- 3 tho)
___________ EXHAUST___INTAKE
LIFT (valve) .410" ___ .422"
Duration 165 deg 175 deg
duration... we measured when it opened, and measured when it closed.... we got big numbers so we divided by 2 to get what we have above... not sure those are correct... but those numbers also coincide to half lift....
so raby/brett/clayton others... what can you tell me about this cam? does it fit a WEB/engle profile?
motor was rebuilt many years ago... its a 1911.. and the cam definitely had visible overlap (both valves open for a few degrees, one closing, one opening)
swood
post Nov 4 2006, 10:20 PM
You guys won't be able to figure it out without the chopstick method.
Aaron Cox   Mystery CAM - what can you tell me about this lift and duration   Nov 4 2006, 08:47 PM
SLITS   1.) Was valve lift measured at the valve or lifte...   Nov 4 2006, 09:15 PM
Aaron Cox   yes. measured lift at the valve.... (no ratio cal...   Nov 4 2006, 10:10 PM
Brett W   Something is not right with your numbers. When yo...   Nov 4 2006, 10:15 PM
Aaron Cox   ahh.. i KNEW we screwed up the duration... we mea...   Nov 4 2006, 10:18 PM
swood   You guys won't be able to figure it out withou...   Nov 4 2006, 10:20 PM
KaptKaos
- Lo-Fi Version Time is now: 5th July 2025 - 09:56 AM
