> how to adjust brakes, how do you?
shaggy
post Nov 11 2006, 09:36 PM
mechanic/welder/fabricator
i just replaced all 4 corners.
rebuilt front hubs. changed rotors.
changed front calipers.
changed rear calipers.
changed rear rotors.
i bled the brakes 2 times.
the brakes feel soft.
i will press on the pedal but they wont engage firmly but if they were pumped they they would engage better, but they still arent what they should be. they feel like they need to build up pressure. im sure there is no air in the lines, ive bled then twice and the second time found only clear streams of fluid.
i have the stock brake set up with the 17mm master cylinder.
im using ceramic front pads.
and organic backs.
as i was bleeding the brakes there was a rubber line on the back(toward the driver) side of the resivoir that had broken off. i couldnt figure what it was going to so i just capped it.
anyone have any idea whats going on?
thanks
-jim
Elliot_Cannon
post Nov 11 2006, 10:25 PM
Group: Retired Members
Sound like you still got some air in there. Keep bleeding the brakes. You could also have air in the proportining valve. It can be a source of trapped air in the system. Lots of past threads about this problem. Try searching. I hope you didn't cap off one of the two supply lines from the reservoir to the mc. Did you?
Cheers, Elliot
shaggy   how to adjust brakes   Nov 11 2006, 09:36 PM
Elliot Cannon   Sound like you still got some air in there. Keep ...   Nov 11 2006, 10:25 PM
terrymason   My understanding is that if you can pump up the br...   Nov 11 2006, 11:41 PM
So.Cal.914   Did you adjust the PB on the rear calipers? If not...   Nov 11 2006, 11:55 PM
shaggy   how do i adjust the PB(?) on the rear brakes? loo...   Nov 12 2006, 02:02 AM
Spoke
- Lo-Fi Version Time is now: 2nd April 2026 - 03:10 PM
