> one more stupid question about headlight wiring ...
post Nov 21 2006, 12:52 PM
Resident German
so, i got my new H4 headlights with the 55/100 bulbs. i also got 4 good relays to make sure the headlights get all the juice they need.
here's my question:
- shouldn't i be able to just run 1 (one) heavy gauge wire to each side?
i might be thinking this through too much, but i never use the low beams and high beams at the same time, so why not share the 12V feed for both (per side) ???
does that make sense at all?
(IMG:style_emoticons/default/confused24.gif) Andy
DonTraver
post Nov 22 2006, 12:50 AM
I ran 1 10 gage wire from the battery to the front trunk, installed a fuse panel at each end, then 2 relays, 1 for low, 1 for high. Before I did that I had a 2 volt drop between the battery and the headlights, now it's .2 volts. Lots more light from those halogens now. Also ran a couple of extra wires while I was at it, never know when you might want to install something else, CD player, etc.
Good Luck, Don
McMark
post Nov 23 2006, 12:28 PM
914 Freak!
QUOTE(DonTraver @ Nov 21 2006, 10:50 PM) *
Good Luck, Don
Damn! That's SMART!!! I've definitely filed that away for future projects. (IMG:style_emoticons/default/smilie_pokal.gif)
SirAndy   one more stupid question about headlight wiring ...   Nov 21 2006, 12:52 PM
michel richard   I'll let others speak to the details of wiring...   Nov 21 2006, 12:58 PM
Dave_Darling   You can run just one wire up to the relays, if you...   Nov 21 2006, 01:03 PM
TonyAKAVW
  Nov 21 2006, 01:13 PM
SGB   Yep, I just sent one big 'ol (fused) ten guage...   Nov 21 2006, 08:14 PM
Aaron Cox   andy.... you could probably get away with 1 relay...   Nov 21 2006, 11:25 PM
DonTraver   I ran 1 10 gage wire from the battery to the front...   Nov 22 2006, 12:50 AM
McMark
- Lo-Fi Version Time is now: 2nd April 2026 - 08:45 PM
