> A couple brake questions, For you 911 conversion guys
BMXerror
post Nov 28 2006, 04:53 PM
Question 1: Which 911s used the 4 piston calipers? All I found on pelican for calipers were very similar to the 914-4 calipers (weaksauce).
Question 2: What in the suspension needs to be changed to go to 911 brakes? In other words, are the control arms different, or just the spindles? I know I'll have to go to five lug, but I do know what all is necessary to do that.
Question 3: What size rims do I have to run to stuff say 911 sc or turbo brakes under them?
Question 4: Any other changes I would have to do to the brake system besides calipers and rotors? I'm already running a 19mm master cylinder.
Feel free to answer any or all. Thanks for any help.
Mark D.
Jeroen
post Nov 28 2006, 06:28 PM
Region Association: Europe
964 (also known as Carrera 2 and Carrera 4) are 1990 through 1993 or 1994
944Turbo calipers are the same
You'll need to make some very minor changes on the mountingholes on the caliper
Use Carrera 3.2 (1984-1989) rotors
For the 911 struts, these come with a spacing for the caliper mounting bolts in 3" and 3.5"
Get the later ones 1978 through 1989 - SC or Carrera 3.2
Some earlier cars also had 3.5" spacing, but I'm not quite sure which ones... So be sure to check
I don't know your car's specs, but the 4 piston calipers may be overkill on a narrow bodied car
I'm pretty sure SC or Carrera 3.2 brakes would suffice
BMXerror   A couple brake questions   Nov 28 2006, 04:53 PM
Jeroen   1: 964 (carrera 2 and 4) and later 2: you need 911...   Nov 28 2006, 05:11 PM
Travis Neff   Answer 1: 964 cars and newer, 944 turbo, 928 Answ...   Nov 28 2006, 05:14 PM
BMXerror   In response to Jeroen's question, it's not...   Nov 28 2006, 05:48 PM
VegasRacer   Adding some sort of ducting to get cool air on the...   Nov 28 2006, 06:02 PM
race914   Here's a couple of many options out there 4 p...   Nov 28 2006, 06:21 PM
Jeroen   964 (also known as Carrera 2 and Carrera 4) are 19...   Nov 28 2006, 06:28 PM
Dan (Almaden Valley)   You do not have to go to 5 bolt to get vented roto...   Nov 28 2006, 06:31 PM
BMXerror
- Lo-Fi Version Time is now: 2nd April 2026 - 03:37 PM
