| BMXerror |
Nov 28 2006, 04:53 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Question 1: Which 911s used the 4 piston calipers? All I found on pelican for calipers were very similar to the 914-4 calipers (weaksauce).
Question 2: What in the suspension needs to be changed to go to 911 brakes? In other words, are the control arms different, or just the spindles? I know I'll have to go to five lug, but I do know what all is necessary to do that. Question 3: What size rims do I have to run to stuff say 911 sc or turbo brakes under them? Question 4: Any other changes I would have to do to the brake system besides calipers and rotors? I'm already running a 19mm master cylinder. Feel free to answer any or all. Thanks for any help. Mark D. |
| DanT |
Nov 28 2006, 06:31 PM
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
You do not have to go to 5 bolt to get vented rotors.
You will need to go to 5 bolt to get 4 piston calipers. I did M calipers on the front with vented SC rotors using the magical mythical Billet 4 bolt front hubs. M calipers give you plenty of braking and the vented rotors keep the brakes from fading for 30+ minute sessions. You don't need to use the brakes much on a 4 cylinder 914 (IMG:style_emoticons/default/biggrin.gif) say to yourself....momentummmmmm, momentummmmmmm (IMG:style_emoticons/default/driving.gif) These brakes work great...with stock rear brakes and removing the bias valve and replacing it with a T. My car is used to TT/DE and Axs. For a 4 cylinder car you just don't need that much brake. (IMG:style_emoticons/default/blink.gif) Attached image(s)
BMXerror A couple brake questions Nov 28 2006, 04:53 PM
Jeroen 1: 964 (carrera 2 and 4) and later
2: you need 911... Nov 28 2006, 05:11 PM
Travis Neff Answer 1: 964 cars and newer, 944 turbo, 928
Answ... Nov 28 2006, 05:14 PM
BMXerror In response to Jeroen's question, it's not... Nov 28 2006, 05:48 PM
VegasRacer Adding some sort of ducting to get cool air on the... Nov 28 2006, 06:02 PM
race914 Here's a couple of many options out there
4 p... Nov 28 2006, 06:21 PM
Jeroen 964 (also known as Carrera 2 and Carrera 4) are 19... Nov 28 2006, 06:28 PM
BMXerror ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:10 PM |
