Hydralic Clutch |
Hydralic Clutch |
pjhaun |
Dec 1 2006, 11:09 PM
Member Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None |
Is it possible to use the brake fluid reservoir to feed the hydralic clutch? Or will this cause brake system problems?
Thank You!!!! Phillip J. Haun Oak Harbor, WA. |
ClayPerrine |
Dec 2 2006, 06:40 AM
Life's been good to me so far..... Group: Admin Posts: 15,503 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The kit that Rich Johnson sells for a hydraulic clutch works that way. There is no problem. The amount of fluid that is actually moved under braking is very small. The extra is there to take up the slack when the pads wear. If you lose the rear brakes, your clutch will still work, until it leaks out all the fluid. If the clutch fails, you can lose your rear brakes, if you have a leak.
And it won't affect the front brakes at all. That's why we have split master cylinders......Redundancy. |
Lo-Fi Version | Time is now: 1st June 2024 - 09:45 PM |
