| FB914 |
Dec 5 2006, 03:03 PM
74 alaska blue 2.0 ![]() ![]() Group: Members Posts: 63 Joined: 1-March 05 From: Philly Member No.: 3,689 |
I'm into the 3rd week (part time of course) of a rear bearing replacement project that has been a problem. I've been following the Pelican Parts recomended process from there tech article and that has been helpful. The problem is that the bearing broke apart as I tried to drive it out of the trailing arm. Only the outer ring or outer race of the old bearing is left and it does not want to budge out of the trailing arm. The pelican article says to use brute force and knock it out but I'm afraid of damaging the trailing arm. Anybody ever had this issue and if so, how did you get the bearing out? Thanks as always for your helpul replies.
Frank B |
| Eric_Shea |
Dec 5 2006, 09:42 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I agree Chris but I think there's a problem here... Frank's missing most of his bearing. Not much to grab on to.
(Go Bears) |
FB914 rear bearing replacement - week 3 Dec 5 2006, 03:03 PM
Headrage I used a brass punch and beat the holy crap out of... Dec 5 2006, 03:16 PM
Eric_Shea Frank,
Do you have compressed air and an air hamm... Dec 5 2006, 03:18 PM
FB914 Thanks Eric:
If I need to take the trailing arms ... Dec 5 2006, 03:49 PM
Brad Roberts I dont try to get them out "softly" I us... Dec 5 2006, 03:20 PM
ChicagoChris Is it on the car or off?
Off brute force usually ... Dec 5 2006, 03:27 PM
Heeltoe914 You do have to use brute force sometimes. Try find... Dec 5 2006, 03:27 PM
FB914 All:
Thanks for the posts.
The arm is still on t... Dec 5 2006, 03:45 PM
Brad Roberts Frank,
Find a common spot on the tranny and at th... Dec 5 2006, 03:55 PM
ChicagoChris At the risk of :deadhorse:
my way leaves the ar... Dec 5 2006, 07:37 PM
andys
Dr Evil Frank, if you are still having a problem with this... Dec 5 2006, 11:33 PM
FB914
murt I had the same problem about 10 years ago. Instea... Dec 6 2006, 11:56 AM
FB914 ![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 07:06 PM |
