> Very disappointed, am I loosing time on my car?
VINCE
post Dec 5 2006, 10:44 PM
VINCE
I feel very bad tonight. I bought my first 914 one month ago. I am working on it every evening since one month and sometimes until midnight (it is very cold in my garage)... (IMG:style_emoticons/default/sad.gif)
I think I am loosing time. The more I do, the worst it is. The L-jetronic make me crazy (the 914 is a stock 1.8L from 75).
For example, the engine was runnig two days ago (only on idle because if I tried to open throttle the engine was dying): my cold start valve was OK. And tonight, the cold start valve is not working anymore!!! What is wrong? I don't understand.
It seems I have fuel pressure because when I disconnect the fuel pressure regulator I see a fuel spray. I don't understand how this cold start valve is working. Wich sensor is related to the cold start valve?
It is the same thing for the 4 other injectors... I have no fuel spray.
I have tested (according the Haynes diagnostic method) the air intake sensor
and the throttle body and they are OK.
The only thing I am dubious is the temperature sensor II. Where is it? How I disconect it?
I really need to fix it quickly because it is my daily driver. Should I carb? With what carbs? I need the car run in winter but I don't need more hp. Is it possible to find and adapt 40 PDSI? Can I find manifold and throttle linkage for 40PDSI quickly?
Should I try to continue fix my L-Jetronic?
Should I buy an other car?
Please, help me. I am sure some of you have been in the same situation.
Thanks
Vince
VINCE   Very disappointed   Dec 5 2006, 10:44 PM
bd1308   Dont focus on the small little things--step back a...   Dec 5 2006, 11:05 PM
jd74914   Check the grounds. Most electrical problems revolv...   Dec 5 2006, 11:10 PM
Dave_Darling   The cold start valve (CSV) dumps raw fuel into the...   Dec 6 2006, 12:05 AM
Mark Garriott   Go to http://www.ratwell.com Especially limping h...   Dec 6 2006, 12:48 AM
VINCE   Thank you very much for your advice. I feel more c...   Dec 6 2006, 09:43 AM
Vacca Rabite   Hi Vince, Hope you get everyhting fixed up. I k...   Dec 6 2006, 10:28 AM
double-a   i had some of the same problems with my 1.8, and i...   Dec 6 2006, 11:01 AM
VINCE   One more a night in my garage for nothing... I hav...   Dec 7 2006, 07:41 AM
Mid_Engine_914
- Lo-Fi Version Time is now: 2nd April 2026 - 08:55 AM
