| VINCE |
Dec 5 2006, 10:44 PM
VINCE ![]() Group: Members Posts: 19 Joined: 21-November 06 From: Auburn Hills, MI Member No.: 7,245 |
I feel very bad tonight. I bought my first 914 one month ago. I am working on it every evening since one month and sometimes until midnight (it is very cold in my garage)... (IMG:style_emoticons/default/sad.gif)
I think I am loosing time. The more I do, the worst it is. The L-jetronic make me crazy (the 914 is a stock 1.8L from 75). For example, the engine was runnig two days ago (only on idle because if I tried to open throttle the engine was dying): my cold start valve was OK. And tonight, the cold start valve is not working anymore!!! What is wrong? I don't understand. It seems I have fuel pressure because when I disconnect the fuel pressure regulator I see a fuel spray. I don't understand how this cold start valve is working. Wich sensor is related to the cold start valve? It is the same thing for the 4 other injectors... I have no fuel spray. I have tested (according the Haynes diagnostic method) the air intake sensor and the throttle body and they are OK. The only thing I am dubious is the temperature sensor II. Where is it? How I disconect it? I really need to fix it quickly because it is my daily driver. Should I carb? With what carbs? I need the car run in winter but I don't need more hp. Is it possible to find and adapt 40 PDSI? Can I find manifold and throttle linkage for 40PDSI quickly? Should I try to continue fix my L-Jetronic? Should I buy an other car? Please, help me. I am sure some of you have been in the same situation. Thanks Vince |
| jd74914 |
Dec 5 2006, 11:10 PM
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,875 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
Check the grounds. Most electrical problems revolve around messed up grounds.
VINCE Very disappointed Dec 5 2006, 10:44 PM
bd1308 Dont focus on the small little things--step back a... Dec 5 2006, 11:05 PM
Dave_Darling The cold start valve (CSV) dumps raw fuel into the... Dec 6 2006, 12:05 AM
Mark Garriott Go to http://www.ratwell.com
Especially limping h... Dec 6 2006, 12:48 AM
VINCE Thank you very much for your advice.
I feel more c... Dec 6 2006, 09:43 AM
Vacca Rabite Hi Vince,
Hope you get everyhting fixed up. I k... Dec 6 2006, 10:28 AM
double-a i had some of the same problems with my 1.8, and i... Dec 6 2006, 11:01 AM
VINCE One more a night in my garage for nothing...
I hav... Dec 7 2006, 07:41 AM
Mid_Engine_914 ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:52 PM |
