> Very disappointed, am I loosing time on my car?
VINCE
post Dec 5 2006, 10:44 PM
VINCE
I feel very bad tonight. I bought my first 914 one month ago. I am working on it every evening since one month and sometimes until midnight (it is very cold in my garage)... (IMG:style_emoticons/default/sad.gif)
I think I am loosing time. The more I do, the worst it is. The L-jetronic make me crazy (the 914 is a stock 1.8L from 75).
For example, the engine was runnig two days ago (only on idle because if I tried to open throttle the engine was dying): my cold start valve was OK. And tonight, the cold start valve is not working anymore!!! What is wrong? I don't understand.
It seems I have fuel pressure because when I disconnect the fuel pressure regulator I see a fuel spray. I don't understand how this cold start valve is working. Wich sensor is related to the cold start valve?
It is the same thing for the 4 other injectors... I have no fuel spray.
I have tested (according the Haynes diagnostic method) the air intake sensor
and the throttle body and they are OK.
The only thing I am dubious is the temperature sensor II. Where is it? How I disconect it?
I really need to fix it quickly because it is my daily driver. Should I carb? With what carbs? I need the car run in winter but I don't need more hp. Is it possible to find and adapt 40 PDSI? Can I find manifold and throttle linkage for 40PDSI quickly?
Should I try to continue fix my L-Jetronic?
Should I buy an other car?
Please, help me. I am sure some of you have been in the same situation.
Thanks
Vince
Dave_Darling
post Dec 6 2006, 12:05 AM
914 Idiot
The cold start valve (CSV) dumps raw fuel into the manifold. It does so only when two things are true at the same time: 1--the starter is cranking; 2--the thermo-time sensor (TTS) is "cold enough" (probably below about 40 degrees F). The TTS is, as I recall, located below the CSV on the L-jet cars. It may be on a bracket sticking out from the manifold (as on the 2.0 D-jet cars) or it might be tucked partly under the manifold, I don't really recall.
The CSV should not have any effect unless your engine is really very cold indeed.
No signal at all to the fuel injectors sounds like an electrical problem. Check the white wire that plugs into the (-) terminal on the coil. That tells the EFI when to open the injectors. (That is in addition to what the others are telling you, above.)
--DD
VINCE   Very disappointed   Dec 5 2006, 10:44 PM
bd1308   Dont focus on the small little things--step back a...   Dec 5 2006, 11:05 PM
jd74914   Check the grounds. Most electrical problems revolv...   Dec 5 2006, 11:10 PM
Dave_Darling   The cold start valve (CSV) dumps raw fuel into the...   Dec 6 2006, 12:05 AM
Mark Garriott   Go to http://www.ratwell.com Especially limping h...   Dec 6 2006, 12:48 AM
VINCE   Thank you very much for your advice. I feel more c...   Dec 6 2006, 09:43 AM
Vacca Rabite   Hi Vince, Hope you get everyhting fixed up. I k...   Dec 6 2006, 10:28 AM
double-a   i had some of the same problems with my 1.8, and i...   Dec 6 2006, 11:01 AM
VINCE   One more a night in my garage for nothing... I hav...   Dec 7 2006, 07:41 AM
Mid_Engine_914
- Lo-Fi Version Time is now: 2nd April 2026 - 10:28 AM
