Painting questions, what nap roller to use? |
swood |
Nov 11 2003, 12:01 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Just Kidding.
I'm cleaning out the engine bay, pretty much sanding down all the glue, removing all the dirt and wire brushing out the rust (just surface, no deep rust). The side and rear panels don't need much in the way of repair, so, can I just lightly sand them and tack cloth it to prepare it to recieve paint? I have a self etching primer for the firewall that's going on nice and smooth. My color is Palma Green Metallic. I'm not sure if metallics are meant to be color sanded much, if at all. I guess that question is more for the exterior, the bay I'm using a single stage paint, so as long as it doesnt run I probably won't worry about the sanding. |
Kargeek |
Nov 11 2003, 10:44 PM
Senior Member Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 |
Slowpoke has some good advice. Acid etch primer is for bare metal- spot prime bare metal areas with this. Go to your paint store and ask about the materials you are using. Prepairation is key for a good paint job. Also, remember that breathing vapors from the new urethane paints can make you very sick so, take precaution and have the proper resprator. DH
Lo-Fi Version | Time is now: 16th June 2024 - 05:05 PM |
