| PRS914-6 |
Dec 26 2006, 11:05 AM
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
I don't have my car here to get measurements so I am hoping someone has dealt with this. I have 69 911S flanges and stub axles (108mm cv's) that work perfect but the flanges are not hub-centric. I would like to modify a set of 77 hub-centric flanges to work if possible since I have an extra pair.
I know the bearings are wider on the 77 flanges. Anyone know what they did different? Is the flange overall length wider to allow a wider bearing or is the bearing fit area machined further towards the flange itself making a wider fit area? Since I have a lathe, I can modify...... Anyone used these? |
| Eric_Shea |
Dec 26 2006, 03:02 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I only have a pile of early bearings in stock currently but I believe the OD on the bearing is larger as well.
Early 911 should be: 35.5mm length of shaft vs. your 40.8mm 42mm diameter of shaft vs. your 42mm 68mm total height vs. 69mm (could be straight edge fudge factor) 33mm base to face vs. your 28mm Let's see what John comes back with. Looks to me like they simply machined more off the backside of the hub for the longer bearing. I believe it's fatter to though (OD of the bearing) as the handbrake assembly changed to a larger bolt spacing with this new bearing. |
PRS914-6 Using mid 70's 911 rear hub-centric axle flanges Dec 26 2006, 11:05 AM
John I have not yet used them, but since more years use... Dec 26 2006, 11:17 AM
PRS914-6
If you already have a pair, why not measure them... Dec 26 2006, 11:33 AM
John When I get home, I can measure an early 911 hub if... Dec 26 2006, 11:42 AM
John I know for a fact that the internal splines are th... Dec 26 2006, 11:44 AM
PRS914-6 OK, that's great. Sometime today, I'll po... Dec 26 2006, 12:02 PM
John
OK, that's great. Sometime today, I'll p... Dec 26 2006, 12:16 PM
PRS914-6 OK, here we go......Flange is off a 1977 911
Dec 26 2006, 02:31 PM
John Since you made such good pics, I'll just post ... Dec 26 2006, 02:35 PM
PRS914-6 And this is why we want this type flange. The rai... Dec 26 2006, 02:46 PM
John That, and I think more of them are the hub centric... Dec 26 2006, 02:53 PM
PRS914-6 John, I labeled the pictures. Should be easier fo... Dec 26 2006, 03:00 PM
PRS914-6 Eric, if you are right, a simple spacer installed ... Dec 26 2006, 03:09 PM
Eric_Shea 5mm correct-a-mundo Dec 26 2006, 03:50 PM
Eric_Shea Costco = Best deal on latex gloves :woohoo:
;) Dec 26 2006, 03:54 PM
PRS914-6
Damn, you a... Dec 26 2006, 04:09 PM
Eric_Shea :rotfl:
HEY! Wait a minute... that's mea... Dec 26 2006, 05:58 PM
Headrage
:rotfl:
HEY! Wait a minute... that's me... Dec 26 2006, 06:18 PM
John I measured one. (Eric, I still have no word from ... Dec 26 2006, 06:28 PM
PRS914-6 Good Job...The spacer would have to be absolutely ... Dec 26 2006, 06:31 PM
smdubovsky Subscribing... (this is a cool thread)
Its relati... Dec 26 2006, 06:52 PM
PRS914-6
Its relat... Dec 26 2006, 07:06 PM
John
Good Job...The spacer would have to be absolutely... Dec 26 2006, 08:06 PM
PRS914-6 Just got an e-mail from Jim Patrick. The later fl... Dec 26 2006, 11:23 PM
John
Just got an e-mail from Jim Patrick. The later f... Dec 27 2006, 12:32 AM
addwestern
[quote name='Eric_Shea' post='838315' date='Dec 2... Dec 27 2006, 04:23 PM
PRS914-6 Nate, I have a whole box for you..... :finger2: ... Dec 27 2006, 04:45 PM
Aaron Cox oooh! these are VERY SIMILAR to what you need ... Dec 27 2006, 05:31 PM
PRS914-6 Aaron, if I get 3 or more who want them, I would m... Dec 28 2006, 01:24 PM
Paul Illick
Aaron, if I get 3 or more who want them, I would ... Dec 28 2006, 03:53 PM
96744 I'll take a pair. Dec 28 2006, 02:35 PM
roadster fan Hey Paul,
nice job on the spacers. I would like ... Dec 28 2006, 02:39 PM
echocanyons Kinda looks like the metal spacer ring on the fron... Dec 28 2006, 03:22 PM
PRS914-6 Guys, I want to make sure we are clear on this. I... Dec 28 2006, 04:47 PM
Aaron Cox
Guys, I want to make sure we are clear on this. ... Feb 25 2007, 06:36 PM
Mark Garriott Under the "Somebody's already done that..... Dec 28 2006, 05:00 PM
PRS914-6 I sold my spacers to another member and I'm go... Feb 25 2007, 12:13 PM
Paul Illick
I sold my spacers to another member and I'm g... Feb 25 2007, 06:01 PM
John
I sold my spacers to another member and I'm g... Feb 26 2007, 01:01 AM
shoguneagle I would be interested in a set of spacers for the ... Feb 25 2007, 05:42 PM
Luke M I'll take a set of spacers for the late 911 hu... Feb 26 2007, 08:52 AM
PRS914-6 OK guys, I have 5 sets of spacers made for late 91... Mar 5 2007, 08:56 PM
John
OK guys, I have 5 sets of spacers made for late 9... Mar 5 2007, 09:18 PM
woobn8r Hello Paul,
Just found this thread....I'm in ... Mar 5 2007, 09:34 PM
Paul Illick PayPal sent (I had dibs early) Mar 6 2007, 05:27 AM
Luke M By adding the spacer arent you pushing the hub out... Mar 18 2007, 04:26 PM
PRS914-6
By adding the spacer arent you pushing the hub ou... Mar 18 2007, 06:08 PM
barrym dragging up an old thread - does anyone know where... Oct 27 2015, 03:42 PM
914Sixer Patrick Motorsports has them on the web site. Oct 27 2015, 04:35 PM
barrym thanks - just found that !
also found the ... Oct 28 2015, 04:39 AM
Luke M
also found the ... Oct 28 2015, 07:00 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th December 2025 - 05:07 AM |
