solex |
Senior Member ![]() ![]() ![]() Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States ![]() |
First thank you all for the help so far, I took some pictures of my 75 before things start to change. So far I have repaired:
- Some electrical problems, mainly related to the defroster heater motor and some interior lights. - Replace the rear struts with Bilsteins HD. - Added Hella H4's up front. - Pressure washed the under carrige (post attached pictures). - Completely flushed the brake fluid - Balanced all 4 tires to correct a vibration at 65 mph. - Purchased a NOS door to replace the drivers door - Purchased a deck lid to repair the original decklid that was missing the bracket for the J-Bolt - Changed the turn signal lenses. On to the questions: Brakes; I replaced the fluid, pressure bled the entire system and the brakes operate poorly. There is no pulling or pulsating, and the pedal feels fine there is simply not enough stopping pressure applied to the rotors. It is impossible to lock up the brakes, although the car will eventually stop I have to be extremely careful. What are your thoughts? Rear Alignment; I noticed that the rear of the drivers side tire is at an angle the back of the tire is farther out then the front of the tire when compared against the fender and the other side of the car. The difference is so much that it would limit the choice of tire width as it appeared to be a problem for the PO. A previous tire must have rubbed on the fender. Is this something that can be fixed by myself if so how would it be done? Attached image(s) ![]() |
solex |
Haven't done an update in a while but a lot has happened which I did not realized it until I typed the list into this post (also very glad the old post is back):
Back dated the entire exhaust All air guides have been powder coated Added sport mounts to the transmission Replaced all shifter bushings Fixed odometer Replaced and fixed all interior lighting Added a NOS drivers side door Repaired drivers side window regulator Replaced air box with a better screen Reversed park on wind shield wipers (and lubed wiper shafts) Cleaned fuel tank replaced steering rack boot Added Dash cover and repaired all loose material on dash Added Camp914 seat adjusters (reattaching vinyl on the seats) Added speaker pods and Boston Acoustic speakers Added new sneakers (205/50 Falkens with Factory Sport Rim, biggest improvement in handling to date!) Rebuilt Distributor and added new vacuum canister Added New/Rebuilt wiring harness from Jeff Rebuilt Throttle Body (still looking for some one to add brass bushings) Added New TPS Tune Up Added new ignition switch Added used visors Added passenger side mirror Repaired trunk latch Added Eric's rebuilt rear calipers Attached image(s) ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 13th June 2024 - 01:51 PM |
