| ahdoman |
Dec 27 2006, 11:12 PM
It's phonetic...Ah-D-O-Man (Audioman) ![]() ![]() ![]() Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
I have an oil temp gauge in my center console. It appears the PO unwired the temp gauge above the fuel gauge and wired the send to the one in the center console. Can I run the two gauges simultaneously? It's not mandatory it's just I don't like having a gauge not working. If I can how should it be wired?
| John |
Dec 28 2006, 02:21 AM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
I believe that if you try to run both gauges from the same sending unit that neither gauge will read correctly. (at least they didn't in my car)
I had the center console gauge and a fuel/temp gauge both installed in my street car when it was a 2.0 and at one time I wired both up. Both gauges would function, but each read about 1/2 what they should have. I didn't calibrate them, just an approximation. I went back and removed one of the two gauges and all was normal. Just my experience. |
ahdoman Oil temp gauge wiring Dec 27 2006, 11:12 PM
markb You need to make sure the sender is correct for th... Dec 28 2006, 01:17 AM
ejm Gauges work by measuring the resistance to ground ... Dec 28 2006, 06:45 AM
McMark Hook up the dash gauge, get a CHT gauge for the co... Dec 28 2006, 10:26 PM
markb
Hook up the dash gauge, get a CHT gauge for the c... Dec 29 2006, 12:58 AM
ahdoman
Hook up the dash gauge, get a CHT gauge for the c... Dec 29 2006, 09:55 AM
John CHT Gauge = Cylinder Head Temperature Gauge Dec 29 2006, 11:42 AM
mikez One's a brand name the other is not....VDO doe... Dec 29 2006, 11:45 AM
ahdoman Per my original post.. I have both a head temp gau... Jan 4 2007, 10:32 AM
Demick Why do you really want two gauges that show the sa... Jan 4 2007, 11:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 07:25 PM |
