| ahdoman |
Dec 27 2006, 11:12 PM
It's phonetic...Ah-D-O-Man (Audioman) ![]() ![]() ![]() Group: Members Posts: 667 Joined: 7-November 05 From: Santa Clarita, Ca. Member No.: 5,084 Region Association: Southern California |
I have an oil temp gauge in my center console. It appears the PO unwired the temp gauge above the fuel gauge and wired the send to the one in the center console. Can I run the two gauges simultaneously? It's not mandatory it's just I don't like having a gauge not working. If I can how should it be wired?
| Joe Bob |
Dec 29 2006, 11:45 AM
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
One's a brand name the other is not....VDO does make a CHT....the sender ring goes around the spark plug in most cases.
ahdoman Oil temp gauge wiring Dec 27 2006, 11:12 PM
markb You need to make sure the sender is correct for th... Dec 28 2006, 01:17 AM
John I believe that if you try to run both gauges from ... Dec 28 2006, 02:21 AM
ejm Gauges work by measuring the resistance to ground ... Dec 28 2006, 06:45 AM
McMark Hook up the dash gauge, get a CHT gauge for the co... Dec 28 2006, 10:26 PM
markb
Hook up the dash gauge, get a CHT gauge for the c... Dec 29 2006, 12:58 AM
ahdoman
Hook up the dash gauge, get a CHT gauge for the c... Dec 29 2006, 09:55 AM
John CHT Gauge = Cylinder Head Temperature Gauge Dec 29 2006, 11:42 AM
ahdoman Per my original post.. I have both a head temp gau... Jan 4 2007, 10:32 AM
Demick Why do you really want two gauges that show the sa... Jan 4 2007, 11:15 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 07:21 PM |
