> cold weather - very high idle, 3500 rpm at startup
cassidy_bolger
post Dec 29 2006, 12:10 PM
My '73 2.0 sat for a week while I was on vacation. I fired it up this morning to head to work, and the idle was super high - 3500 rpm. It has been cold (for this area) last night's low was 30. I tried to back it up and see if things would calm down, but running it made me nervous and I was late for work so I took my backup vehicle. This 914 has been driven nearly every day and has run well since I bought it last spring, so this is unusual.
Where should I start? I checked the throttle cable at the engine, and it isn't stuck. Is something frozen? Should I just try to drive is a few blocks and warm it up?
Thanks,
cassidy
73 2.0
cassidy_bolger
post Dec 29 2006, 08:44 PM
Problem solved, classic lessons learned - again.
(IMG:style_emoticons/default/headbang.gif)
The hose going into the box out of which comes the oil filler neck (crankcase breather perhaps?) was loose. Plugged it in and back to normal. For giggles, I unplugged it and the idle shot back up to 3500. Turns out, I knocked it off when I topped off the oil this morning.
The only other time this car has acted this badly, it was also my fault - I had accidently loosend the wire harnes at the pressure sensor while installing a new battery.
So it is final - I am a clutz. One must think twice before blaming the car, eh?
Thanks for the help gang. Good to see things are up and running.
- Lo-Fi Version Time is now: 8th December 2025 - 11:03 AM
